Plenum Fire. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-02-2010, 05:38 AM   #1
Plenum fire.
Is duct board fire resistant?, is there danger of fire in plenum from elec heat strips?.
SATURN MAN is offline   Reply With Quote
Old 10-02-2010, 07:07 AM   #2
An old Tradesmen
Rewards Points: 6,906
While duct board will burn. It has to get REAL HOT before it will burn.
Got lots of heat pumps with strip heaters ducted in with duct board. No problem from the strip heaters.
If you need proof. Take a small piece of duct board outside, place it on a 2X4. And then use a hand torch or acetylene air torch on it for 15 seconds. Then look at the duct board and the 2X4.
Then take a piece of sheet metal and place it on top of another 2X4, or flip the same 2X4 over, and heat the sheet metal with the torch the same way and amount of time. And look at the 2X4.
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Old Return air plenum for new furnace? Chemist1961 HVAC 1 12-25-2008 10:20 AM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 08:38 PM
Attaching plenum to furnace. hartkem HVAC 6 11-10-2008 02:17 PM
Plenum Design winkydink HVAC 1 11-22-2006 10:28 PM
