Plenum Dimensions - HVAC - DIY Chatroom Home Improvement Forum
Old 03-09-2011, 08:21 PM   #1
plenum dimensions
I live in New Jersey. I am istalling a furnace in the basement in the vertical position with the supply air passing thru an AC coil at the top and then into a plenum.
1) What is the minimum distance allowed from the top of the plenum to the floor joists above?
2) What is the minimum height allowed for a plenum?
3) What is the minimum distance allowed between the top of the plenum and the top of the starting collar connecting the plenum to the trunk?
4) What is the minimum distance allowed between the bottom of the plenum and the bottom of the starting collar?
Hermand is offline   Reply With Quote
Old 03-09-2011, 09:10 PM   #2
Typically, plenums are 36" tall and it can go all the way to the rafters If you want...some require 1" from anything combustable, but that is in re to flue pipe, not plenum.
Don't pull a duct off of the top; other ducts should be appx. 6-12" from the top and 6-12" from the bottom ( the farther, the better).
Poppyloppy is offline   Reply With Quote
Old 03-09-2011, 11:48 PM   #3
30 year tech
hvac122's Avatar
Here the Plenum and duct must be 1" from combustables for a minimum of 3'. Most top takeoffs are set up for the supply duct to be Don 1" from the joists. The return should be tight to the joists.
hvac122 is offline   Reply With Quote
Old 03-10-2011, 09:30 AM   #4
Does the plenum height include the height of the AC coil?
Old 03-10-2011, 11:02 AM   #5
nOPE.
Old 03-10-2011, 01:24 PM   #6
30 year tech
hvac122's Avatar
Your Plenum length is going to be the length from the top of the coil to 1" below the joist.
plenum splitter design & linkage rebar HVAC 8 01-19-2010 08:18 AM
Old Return air plenum for new furnace? Chemist1961 HVAC 1 12-25-2008 11:20 AM
Attaching plenum to furnace. hartkem HVAC 6 11-10-2008 03:17 PM
Removing Extended Plenum Calm_Blue_Ocean HVAC 15 01-07-2008 06:22 PM
Plenum Design winkydink HVAC 1 11-22-2006 11:28 PM
