Plenum Cap - HVAC - DIY Chatroom Home Improvement Forum
Old 08-09-2011, 03:40 PM   #1
plenum cap
I am new to business. I have installed a few furnaces, all have been upright with upward air flow. My question is when buying plenums they always ask if I need a cap..Are the caps used if the are air flow changes direction at the out end of the plenum? The few that I have installed all had the duct work right above the furnace. No such thing as a silly question right?
75Porsche is offline   Reply With Quote
Old 08-09-2011, 04:30 PM   #2
An old Tradesmen
Rewards Points: 6,860
A plenum often stops just under the joist, and the trunk then taps off the side/front, or rear of the plenum, so a cap is needed for them.
Old 08-09-2011, 04:51 PM   #3
Thank you for your reply, that's what I thought. So far my few have been straight up. Is it a good idea to always wrap the plenum in insulation? This is in an area of California where the winter is pretty mild.
Old 08-09-2011, 04:55 PM   #4
An old Tradesmen
Only if its in an area that if you have A/C the plenum will sweat. if the furnace is in a utility closet or basement that doesn't get very cold, then leaving it unwrapped will help keep that area a little warm, and no harm is done.
plenum dimensions Hermand HVAC 5 03-10-2011 12:24 PM
Old Return air plenum for new furnace? Chemist1961 HVAC 1 12-25-2008 10:20 AM
Attaching plenum to furnace. hartkem HVAC 6 11-10-2008 02:17 PM
Removing Extended Plenum Calm_Blue_Ocean HVAC 15 01-07-2008 05:22 PM
Plenum Design winkydink HVAC 1 11-22-2006 10:28 PM
