Plenum - HVAC - DIY Chatroom Home Improvement Forum
Old 10-22-2009, 01:36 PM   #1
plenum
well, I got through the takeoff thing! BUT.. as I put the plenum together today, I thought.. there are no metal brakes.. this was a "plenum pkg. won't it buckle every time it kicks on? I do not have room for a canvas connector.. that is what I should have done......maybe I should still huh?
P.S. this is a residential 90k 2 stage NOT variable blower........
sixty7flh is offline   Reply With Quote
Old 10-22-2009, 04:26 PM   #2
An old Tradesmen
Rewards Points: 6,480
Depends on how well you sized your trunk and supply branches.
Canvas can still be used between plenum and trunk line. Or plenum and furnace.
Canvas will NOT stop popping of plenum if your trunk and supplies are under sized.
Old 10-22-2009, 06:50 PM   #3
Old Newbie
I had a call last week; the lady was afraid to use her furnace.
Every time the fan started/stopped there was a loud bang.
The duct sizes were acceptable, but only 2 (yes two) 5" round ducts were connected to the return system.
So, beenthere is right.
Your plenum size is OK.
The fact that it has no cross breaks may or may not cause popping depending on what gauge it is.
Tell us more about this 'plenum package'.
Where did you get it?
tinmanrob is offline   Reply With Quote
Old 10-22-2009, 07:15 PM   #4
got all the stuff at johnstone.... my takeoff I ended up with was a 10 (w) by 20 (h) going to a 8 x 24, then a short trunk,"t"ing... 2", into a trunkline.. going approx 25 ft each way... that starts out 16x8, then 14, then 12.. both ways.... I also am gonna be taking off one 6" right off the plenum, for (1) register.. oh yea, the plenum is 20x20x48,
Old 10-25-2009, 12:28 AM   #5
Actually it has to do with the plenum gauge as well!
You could use some pro advice,on site.
dash is offline   Reply With Quote
Unclogging HVAC line at the plenum tam HVAC 4 05-05-2009 06:48 PM
Old Return air plenum for new furnace? Chemist1961 HVAC 1 12-25-2008 11:20 AM
Attaching plenum to furnace. hartkem HVAC 6 11-10-2008 03:17 PM
Removing Extended Plenum Calm_Blue_Ocean HVAC 15 01-07-2008 06:22 PM
Plenum Design winkydink HVAC 1 11-22-2006 11:28 PM
