Old 12-02-2011, 11:11 PM   #1
Please help - wiring thermostat...
Hi,
my thermostat (Totaline model # P374-1100) just stopped working. the digital screen is dead and no red light. It was working just fine the day before so i'm guessing the motherboard is fried. i am trying to change it but all the ones at home depot use batteries and mine is fully hardwired. can i just replace it with the new ones even though i will have extra wires? i'm including a picture of how it is wired now (i haven't done anything to it yet)... thanks! Jen
jenL is offline   Reply With Quote
Old 12-02-2011, 11:31 PM   #2
I'm Your Huckleberry
Can you please confirm the letter at each terminal that each color wire is connected to? It's very hard to see.
wire color - letter
Green-G
Red-R
Brown-C
so on and so forth. You have a heat pump? You have an electrical testing meter?
Doc Holliday is offline   Reply With Quote
Old 12-02-2011, 11:33 PM   #3
HVAC Tech/ Browns Fan
That is hook on common that is t-stat is wire hot all times. That is t-stat may not be the problem. It is a short in 24 volts and the 3 amp fuse is blown.
Tator1076 is offline   Reply With Quote
Old 12-02-2011, 11:35 PM   #4
You need find the short. You need look at low voltage wiring from t stat inside the unit and outside. Ps on the new t stat were it says do not use spot. That is for the common wire.
Old 12-02-2011, 11:38 PM   #5
That's why I asked if she had a meter. Me thinks fuse or transformer went bye bye. Stat is okay.
Old 12-03-2011, 06:29 AM   #6
jkv
Jen you can put a new t-stat on but I would check the fuse inside the furnace there should be a 3 A fuse comeing out of the transformer. The r wire in your t-stat is the hot or power to the t-stat the batteries in the one you are looking at controls the LED at the t-stat. Hey doc what is with (me thinks) To much freon?
jkv is offline   Reply With Quote
Old 12-03-2011, 08:52 AM   #7
Judging by your inability to spell the very simplest of words in the English language, printed like a dyslexic deaf dumb and blind retarded first grader I'd have to assume that, yes. But even then, freon would be the least of your worries, me thinks.
COMING wOulD bE CoRrEcT. Da.
Old 12-03-2011, 08:56 AM   #8
oOps, i dUhn fOrgOt A eMotIcOn tO eNsUrEs dAt yOus nOEs dAt i wUz dUh gOkIng.
Old 12-03-2011, 09:02 AM   #9
lucky I didn't use, "bye bye bye bye bye bye."
http://www.youtube.com/watch?v=TEGHCSDuggw
Old 12-03-2011, 09:12 AM   #10
jkv
Good one Doc. Did you get that heat pump up & running?
Old 12-03-2011, 09:43 AM   #11
On my way to Century (Rheem Ruud distributor) now but yes. According to Century Tech Support, these two brands are the only ones that energize on heat with the use of B. Also said they were the only ones who had it right. The guys at American Standard (Aces) even agreed yesterday when I was there picking up an ignitor and browsing for a compatible stat for the Ruud.
All else use O energized on cool and right now I have O from the old Carrier Comfortmaker stat (no B present. no switch either) hooked to the B from the defrost board on the Ruud heat pump so the calling status is backwards.
There's an entire thread on it.
I'll be taking some more pictures to add to my life long portfolio , posting in a few.
Adios amigos.
2 zone damper 2 thermostat wiring help kostia HVAC 10 08-22-2010 10:57 AM
Thermostat wiring dimbulb HVAC 16 08-20-2010 12:49 PM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-10-2010 12:58 AM
Unexpected wiring found on existing thermostat mportobello HVAC 12 03-30-2010 07:11 AM
Thermostat wiring question cpuken HVAC 4 12-14-2009 08:32 PM
