Please Help Steam Heat / Coil - HVAC - DIY Chatroom Home Improvement Forum
Old 12-19-2011, 01:52 PM   #1
please help steam heat / coil
When i bought my house the main part of the house is steam heat, but the extention that was added is baseboard heat where they used the coil to heat, had no problems till we built a small doorma above that room so the problem now is = they taped into the existing curc pump and what happens is if the that zone runs on its own it works fine, but when the steam side runs too the pressure builds up to about 40lb then the Relief valve leaks water please help
Miccky13 is offline   Reply With Quote
Old 12-19-2011, 02:04 PM   #2
HVAC Tech/ Browns Fan
You may have too much air in the line. You need to get a HVAC company out to help you. To able explain what to do on here will be very hard and don't want you to do any damage to the system.
Tator1076 is offline   Reply With Quote
Old 12-19-2011, 02:08 PM   #3
please explain i understand plumbing im just stumped on this
Old 12-19-2011, 02:12 PM   #4
please explain i understand pluming im just stumped with this on
Old 12-19-2011, 02:21 PM   #5
You should have some air ports some were in line of the system
Steam heat and coil is used for new living area Miccky13 Pest Control 0 12-19-2011 01:09 PM
Governments Renewable Heat Incentive SMurray Green Home Improvement 1 10-24-2010 08:30 AM
Steam heat Boiler burns, steam doesn't travel? tomhere HVAC 18 10-16-2010 03:01 PM
Converting steam heat to hot water??? pcampbell HVAC 31 02-17-2009 08:26 PM
change steam radiant heat to outside wood water heat Monteu HVAC 5 02-13-2007 11:19 AM
