Please Help: Relocating A Thermostat - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-06-2012, 05:28 PM   #16
yes those 2 flat head screw should be loosened to remove from sub-base. I want to say there is really 3 just can't see the 3 rd in the pic but I am not sure.
The screws don't typically remove all the way they are held in place so you don't loose them. They do unscrew unit you feel they are not connected.
turnermech is offline   Reply With Quote
Old 08-06-2012, 07:42 PM   #17
I think I see the third screw hiding under the red wire just below the .25 on the heat anticipator.
Hvacwin is offline   Reply With Quote
The Following User Says Thank You to Hvacwin For This Useful Post:
Missouri Bound (08-06-2012)
Old 08-07-2012, 03:27 PM   #18
I got the control plate off. Just needed to use a slotted screw driver with a snug fit. The wire colors are actually labelled on the wall plate, only they've used a blue wire for what is labelled green.
Notice that the red wire is touching screws at both "R" and "A."
Okay. I shut the circuit breaker off for the furnace. LED is out at the furnace control panel. Left the circuit breaker for the AC/condenser on.
peterk312 is offline   Reply With Quote
Old 08-07-2012, 05:21 PM   #19
I decided to just reconnect the new thermostat wire at the furnace control panel rather than splice wires. Everything is clearly visible and labelled so no worries. I used the blue wire instead of green because that's the way it was. Silly, isn't it?
Put the mounting plate on the wall in the new location, level as instructed above.
Everything else went together fine. Still works. Here it is in the new location next to the utility closet door. That's the return air vent below the door.
Easier than I first thought. Just need to patch the wall now at the old location. Thanks much for the help. I hope the pics will help others in the future who might be relocating one of these old thermostats.
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 10:53 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 11:46 AM
Relocating the Thermostat.... donste2010 Electrical 5 01-20-2010 10:02 PM
