Please Help No Heat Upstairs Radiator Downstairs Is Fine !!! - HVAC - DIY Chatroom Home Improvement Forum
Old 02-12-2008, 01:12 PM   #1
My temporary fix has been to force water into the furnace and bring it to about 11psi. I then bleed the radiators until i get water. This works for a few weeks or so then I lose heat agian. It seems that i lose water and pressure. I have no leaks in the house. Its a small area 800 sqft to heat so its not a big system....any ideas or advice/help would be great!!!!
Thank You
CARL7480 is offline   Reply With Quote
Old 02-12-2008, 05:52 PM   #2
biggles's Avatar
hot water radiators with a circulator is the pump running during the heating cycle in the boiler...and your working with 1 stat?
Old 02-12-2008, 08:43 PM   #3
i cant tell if its working i cant feel or hear anything.... its hot and the pipe coming out of it is hot
Old 02-13-2008, 02:46 PM   #4
a hot water system is a boiler not a furnace. Just mentioning it because it threw me off answering another thread....
11psi is normal...nothing forced about..is your water feed valve on??..it should be on all the time and right after it should be your h2o regulator..h2o will auto feed and keep the pressure up to where it should be....
next...is the ciculator running???? 1 circulator??? zone valves??? how many thermostats???
if you have one stat (one zone) you are prob. just running low on water and water will feed the lowest loop first.
econoline is offline   Reply With Quote
Getting a House..heatpump or no? DavidsCPU HVAC 10 02-07-2010 10:22 PM
Testing FuelMaster 21 Module? Heat Pump no Run. thehotrod11 HVAC 3 12-29-2007 02:11 PM
HVAC Upstairs QUESTION Statecowboy HVAC 1 09-15-2007 11:15 AM
baseboard heat upstairs not working TraceyLee HVAC 1 10-23-2005 05:47 PM
