Please Help Me Stop My Oil Fired Boiler From Banging At The End Of Each Cycle! - HVAC - DIY Chatroom Home Improvement Forum
Old 01-09-2009, 02:45 PM   #1
Smile
Please help me stop my oil fired boiler from banging at the end of each cycle!
I have an oil fired boiler in my home- age unknown was here when we bought the place over 7 years ago- recently it started making a very loud banging noise in different zones at the end of each cycle. Sometimes it is on the main floor other times the bang seems to come from the lower level- please help me figure this one out- is there not enough or maybe too much pressure in the system or maybe the water is too hot and needs to be lowered?
all help is appreciated.... I need a good nights sleep
thanks shell
snanancekivell is offline   Reply With Quote
Old 01-09-2009, 02:57 PM   #2
JohnH1's Avatar
Is this a steam or hot water boiler?
JohnH1 is offline   Reply With Quote
Old 01-10-2009, 08:23 PM   #3
oh sorry...it is water
Old 01-12-2009, 10:19 PM   #4
could be an after drip in the nozzle, try starting and stoping it 10 times to work the air out of the nozzle line. use the reset button wait for the flame to come on then shut off. do this 10 times.
thelimit is offline   Reply With Quote
Old 01-13-2009, 05:29 AM   #5
An old Tradesmen
Rewards Points: 7,278
Is this a zoned system(you have more then one thermostat).
If so, some zone vavles close too quickly. So that you get a bang from the waters sudden stop.
Old 01-13-2009, 04:06 PM   #6
Cool
I think you are on the right track with the zone issue- question is how do i fix it- it seems to be an issue with the relay, but i have no idea how to correct it.- your thoughts?
Old 01-13-2009, 04:12 PM   #7
JohnH1's Avatar
Are you saying the noise comes from a relay or just when the relay opens? Also do you have zone valves or just a single pump or both?
Circulation pump on boiler uncleneiler Plumbing 4 06-22-2010 09:01 AM
Boiler w. Hydronic Air & Honeywell Aquastat DanA28 HVAC 1 01-08-2009 04:21 PM
Weil Mclain Boiler Banging After Water Circulator Swap Roamer HVAC 6 12-11-2008 06:42 PM
Oil fired boiler need help with gustavus HVAC 4 11-30-2008 04:41 AM
Hinge door stop fred2007 General DIY Discussions 3 11-11-2007 07:00 PM
