Please Help Me Design A Anti-stratification System! - HVAC - DIY Chatroom Home Improvement Forum
Old 08-11-2010, 11:13 AM   #1
Rewards Points: 20
Please help me design an anti-stratification system!
I am renovating small 1000 sq.ft. 3 story condo, which is located in the mountains at 10k feet.
There is no forced air, just hydronic baseboard heating. The problem is the top floor, is, of course, much warmer than the bottom floor, summer and winter. The unit is facing south, with a lot of window area, so there is significant heat gain in the winter. To make matters worse, the top floor has an 11' ceiling, with the rest at 8'.
I would like to install a small duct and fan system that would force the top floor hot air down to the bottom floor. In addition, I would like to add some method of positive fresh air to help mitigate any inside polutants.
Knowing nothing about what is available today such as fans and controls, I need HELP! Would I be creating a moisture/humidity issue, and if so, how would I remedy it?
Thanks!
simplemind is offline   Reply With Quote
Old 08-11-2010, 12:01 PM   #2
fabrk8r
fabrk8r's Avatar
Do you have the space to add duct between floors? A chase somewhere, or closets on one floor above or below another closet?
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 08-11-2010, 12:07 PM   #3
Rewards Points: 20
Yes, and I think I can create an "exposed" chaise where I don't have closet coverage.
Old 08-11-2010, 01:02 PM   #4
fabrk8r
fabrk8r's Avatar
You could try a small inline fan such as this...
...attached to spiral or snaplock pipe.
If it were me I would get a small air handler and locate it in an out of the way place and run duct, that way the air could be filtered as well as moved.
The Following User Says Thank You to fabrk8r For This Useful Post:
simplemind (08-11-2010)
Old 08-11-2010, 11:23 PM   #5
Rewards Points: 20
as well as moved.
What do you mean by "moved"?
Old 08-12-2010, 09:49 AM   #6
fabrk8r
fabrk8r's Avatar
What I meant was the air could be "moved" around in the building to prevent stagnating or "stratification".
A side benefit of having it go through an air handler is that there will be a filter rack with an easily accessible filter rack which, by using cheap replacement filters, will help clean the air as it is "moved".
simplemind (08-12-2010)
Old 08-18-2010, 09:22 AM   #7
Rewards Points: 20
Originally Posted by stevephillips79 View Post
Hi friend,
A chase or other conduit for air would be the key to making this work. I finally checked back here to find two really good posts, thank you!
1) The condo is 1000 sq. ft., ~300 ft./floor.
2) Open stairway from bottom to top.
3) Bottom floor is 1/2 basement or 1/2 underground.
4) Town is located at (10k elevation)
i am sending you this link and i am sure it will help you
http://residential.fantech.net/resid...y-ventilators/
Thank you
Want to get-on Google's first page and loads of traffic to your website? Hire a SEO Specialist from Ocean Groups seo specialist
Thanks! I have an ongoing discussion over on HVAC talk also.
Need plumbing system from Soviet Era mats. MDarg Plumbing 2 10-30-2009 11:23 PM
Water Purification System - Maintenance Qs cjcocn Plumbing 1 11-18-2008 08:31 AM
New House, new system, poor cooling Faulknertw HVAC 15 07-08-2008 11:06 PM
Size A/C system properly 70stang HVAC 1 03-26-2006 08:22 PM
Replace furnace, coil and duct system sps123 HVAC 2 01-07-2006 11:56 AM
