Please Help Me Correctly Size My A/C Condenser - HVAC - Page 6 - DIY Chatroom Home Improvement Forum
Old 08-01-2013, 12:09 PM   #76
Hvac Pro
yuri's Avatar
Rewards Points: 144
silver foil duct tape from HDepot.
Old 08-01-2013, 12:11 PM   #77
Hi Yuri,
Thanks.
Unicornz0 is offline   Reply With Quote
Old 08-01-2013, 12:16 PM   #78
Hvac Pro
yuri's Avatar
Rewards Points: 144
Yur Welcome. may B in the dryer venting dept or sheet metal dept.
The Following User Says Thank You to yuri For This Useful Post:
Unicornz0 (08-01-2013)
Old 08-01-2013, 03:46 PM   #79
An old Tradesmen
Rewards Points: 7,816
Silver foil tape.
Old 08-07-2013, 11:17 AM   #80
What is the maximum temperature differential, inside vs outside, from a properly matched new residential A/C system, when the outside temperature is 100?
Thanks,
Uni
Old 08-07-2013, 05:48 PM   #81
An old Tradesmen
Thanks,
Uni
That depends if 100 is the design temp. or the once every few year extreme temp.
In PA, if it hits 100 outside, indoor temp of 80 is not uncommon. in many parts of AZ, should still be able to keep it 70 inside.
HVAC condenser not wired properly? LynnX HVAC 9 01-24-2014 08:40 PM
A/C Condenser Disconnect Box whattodo Electrical 18 03-22-2013 09:45 AM
Proper trunk/duct size? gjones HVAC 7 12-06-2011 07:18 PM
A/C condenser circuit size Rustygaff Electrical 23 10-30-2011 07:15 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 12:08 AM
