Old 11-04-2009, 11:25 PM   #1
Default Please Help! Gas Heating Lockout!
Thanks for the help with the "strange problem with my furnace".
I followed Plumer101's instruction and found out the service code, which is 21 - Gas Heating Lockout. Control will NOT auto reset. Check for : Stuck gas valve relay on control or miswire to gas valve circuit.
I then followed Houston204's instruction and checked the ground wire. It seems connected.
Can anyone help me with this? It is getting cold here at Atlanta. Is it possible to fix this problem by myself? Should I call a technician to come in and fix it?
Thanks a lot!
chenjijc is offline   Reply With Quote
Old 11-05-2009, 01:38 AM   #2
Default tech time!!!!
Thanks a lot!
this is past a diy prob . u need a tech with meters and diagnostic skills , dont be fooling around with the relays or jumpering stuff , be safe........Jack
psilliman001 is offline   Reply With Quote
More On This Topic
Before you call someone to come fix your furnace, you may want to find out what's wrong. Read on to learn how to check your furnace for any possible malfunctions. Read More »
Finding the EGR Valve
Finding the EGR Valve by Expert Village
In this clip we're going to talk about the proper way to remove and replace the EGR valve or exhaust gas recirculation valve on a 1997 Ford F-150. In this step we're going to talk about the proper method for locating your engines EGR valve. The EGR valve... Read More »
Hi my name is Mark Delgado with American Auto Service for expert Village. Once in the evaporator coil it will obsorb the heat from the interior of the vehicle. Because the evaporator coil is deep inside the dash I just want to show an example of what it... Read More »
Ice fishing is a popular pastime in the northern states where the lakes and rivers freeze. The ice fishing houses range in sophistication from a little pup tent to a fully built, functioning home. There are several ways to heat the ice fishing house... Read More »
Hi! My name is Jeff Thompson for Thompson Air hot air balloon rides and I am here with Expert Village and today we are going to talk about the bottom end. The bottom end is what pilots refer to as their basket of a hot air balloon. Anything that goes... Read More »
Mini Split for heating in cold climate landev HVAC 3 01-25-2009 01:13 PM
Carrier Furnace: Gas Heating Lockout kkf HVAC 16 06-11-2008 04:34 PM
Electrical consumption of baseboard heater CowboyAndy Electrical 7 03-24-2008 09:27 PM
Central Heating Frustration SassySue General Discussion 4 11-29-2007 08:46 AM
Trane XE80 Heating Question, Please help!!! Stephen1977 HVAC 3 01-30-2007 08:34 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
