Please Help, Furnace Not Working!!!!!! - HVAC - DIY Chatroom Home Improvement Forum
Old 03-31-2011, 01:23 PM   #1
Sfeyelectric's Avatar
Please help, furnace not working!!!!!!
My furnace quit working this morning, It reads pressure switch stuck open! What can i do to fix this?
Sfeyelectric is offline   Reply With Quote
Old 03-31-2011, 01:49 PM   #2
JJboy's Avatar
Check if there is any obstruction in exhaust line . Also check pressure switch tube for any obstruction. Get a mutimeter and check if the pressure switch sensor is ok.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 03-31-2011, 03:23 PM   #3
Hvac Pro
yuri's Avatar
Rewards Points: 1,396
Post the make model and serial #
Old 03-31-2011, 03:31 PM   #4
luxaire
Model- GM9S100C16UP11K
serial- WOK7289700
Old 03-31-2011, 06:17 PM   #5
Hvac Pro
yuri's Avatar
Remove the front panel and start the furnace. Does the ventor fan that pushes the exhaust out the plastic vent pipes run? Check the intake and exhaust pipes outside for blockage. Bags or other debris can get sucked in the intake.
Old 03-31-2011, 06:26 PM   #6
It does run and than ends up shutting off. Where would the intake be located? I checked the exhaust already!
Old 03-31-2011, 06:34 PM   #7
Sounds like a plugged drain to me blow out condensate line with compressed air
heatycooly is offline   Reply With Quote
Old 03-31-2011, 07:20 PM   #8
Hvac Pro
yuri's Avatar
If it is a 2 pipe system then it should have an intake pipe also going outdoors. One pipe system takes the air from the basement. Carefully remove the hose from the pressure switch and poke a wire thru the port on the plastic collector box where it attaches. DO NOT suck or blow on the pressure switch or it gets damaged. Blow thru the hose in case it has water in it. Check the drain from the furnace and the condensate trap. May have to remove it and flush it with hot water and bleach. Beenthere is a York/Luxaire tech and may know that furnace better than me.
tiling under new furnace gramps416 Flooring 4 01-09-2011 11:47 AM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
RUUD furnace not working blower runs ddeatrick99@hotmail.com HVAC 2 01-16-2008 10:55 PM
Furnace not working right TheBillman HVAC 2 11-20-2005 06:31 PM
