Please Help With Furnace - Flame Is Choking! - HVAC - DIY Chatroom Home Improvement Forum
Old 08-26-2013, 11:26 AM   #1
Rewards Points: 89
Please help with Furnace - Flame is choking!
Hi,
Can someone please help me with my furnace? I have an Armstrong furnace about 15 years old. The pressure switch was bad so I replaced a new one but for some reason the furnace doesn't hold a constant flame. The flame went on for about 10 second and off then on...kinda like something is choking.
Thank you everyone for your time!
bcdinh is offline   Reply With Quote
Old 08-26-2013, 11:58 AM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 2,296
post a pic of it with the doors off so we know what kind it is. if it is a high efficiency unit with plastic pipes instead of a chimney check them for obstructions outside.
Old 08-26-2013, 06:35 PM   #3
Rewards Points: 582
check and clean or replace flame sensor....ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
hvactech126 (08-26-2013)
Old 08-26-2013, 06:36 PM   #4
Rewards Points: 1,298
by choking do you mean it is shutting completely off or just lowering or "floating around. A good strong flame should "stand" tall on the burners and burn a nice solid blue.
Alex, I'll take dirty flame sensor for $600.00
danpik is offline   Reply With Quote
Old 08-26-2013, 06:36 PM   #5
biggles's Avatar
check the rounds on that IDF squirrel cage and verify it isn't spinning on he IDF motor shaft
Furnace lights up, but then shuts down soon after... justplumducky HVAC 1 11-18-2012 09:25 PM
flame sensor ducane furnace real madrid HVAC 3 02-17-2012 07:08 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Trane Gas Furnace - blower on but no flame at burners herbert8101 HVAC 2 09-24-2011 08:23 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
