Old 10-06-2011, 09:15 AM   #1
Placement of Cold Air Returns in Basement
Hello Forum
Finishing off my basement in Minnesota. There will be 2 bedrooms. Due to the layout of the rooms and the design of the existing ductwork, I have the same two placement options for cold air returns in both bedrooms: interior part of the room in the ceiling or exterior wall (floor or ceiling). I will be putting the heat registers in the ceiling in both rooms. What is the best option for the cold air returns given my northern climate?
MarathonMikey is offline   Reply With Quote
Old 10-06-2011, 07:17 PM   #2
An old Tradesmen
What kind of supply register, and where will it be placed.
Old 10-06-2011, 09:29 PM   #3
wish you well on your project...my company always tries to provide the best ...If possible we would put high and low cold returns with control dampers to adjust between heating and cooling this would be done on side walls again if possible.....
ben's plumbing is online now   Reply With Quote
Tags
basement, cold air return
cold return and heat vents in basement gaetz1 HVAC 1 02-24-2011 08:56 PM
Insulating basement cold room. blizmore Building & Construction 0 10-14-2010 05:02 PM
Finished Basement Really Cold during summer dk_99 HVAC 3 08-09-2010 05:56 AM
Ugly Cold Floor in Basement Washroom Makes Wife Grumpy slydevil Flooring 7 02-11-2010 09:10 AM
Cold Room in Finished Basement Creekbender Building & Construction 4 01-31-2010 09:54 AM
