Placement Of Baseboard Heaters - HVAC - DIY Chatroom Home Improvement Forum
Old 01-24-2016, 06:09 PM   #1
Rewards Points: 30
placement of baseboard heaters
Ok so i have attached a pic of my basement floor plan.
As you can see i plan on finishing an area of 23 ft wide by 13.4 ft long.
The dark black rectangles represent the 3 windows in this room .
Now this space contains 3 exterior walls. Last wall has opening connecting to existing basement and sharing a wall with garage.
So using the regular formula for baseboard watts x 10 , i need about 3000watt heater.
So i was thinking of 2 baseboards of 1500 w each or should i go 3 of 1000 watts .
My questions are the following , where would you put the 2 or 3 baseboards ?
Usually they go under the windows, but my 2 windows in the 23 ft section are 6 ft apart and not really centered on that long wall ...not sure if the baseboards there would look awkward or should i put them somewhere else.
My only opening in this space is the 4 ft opening you see.
I would like a nice even heat in there.
I was 1st thinking one on each end of opposite walls , but not sure .
What would you do or recommend ?
Also is 2 baseboards of 1500w better than 3 baseboards of 1000w for an even heat ?
Thanks again,
Matt
phantomvs is offline   Reply With Quote
Old 01-24-2016, 07:14 PM   #2
An old Tradesmen
Rewards Points: 6,060
Probably need closer to 5,000 watts.
Old 01-24-2016, 08:54 PM   #3
Rewards Points: 3,204
Hi phanton,
What is your climate and how are those basement walls finished, insulated. Also, how about the wood rim above and sealing it to the top of the foundation. And, what portion of the exterior of those walls is underground.
If the basement walls are well insulated and air sealed at the top the heat loss is low and your placement can easily be where you want them. If everything is poorly insulated it will feel cold regardless of where you install them.
Bud
Bud9051 is offline   Reply With Quote
The Following User Says Thank You to Bud9051 For This Useful Post:
phantomvs (01-25-2016)
Old 01-24-2016, 09:24 PM   #4
Rewards Points: 1,592
The more you can spread the heat out (more heaters) then the more even it will feel across the room. On the other hand you can't fill up all the wall space with heaters because you will then have problems with furniture placement so it's kind of a balancing act.
Bob Sanders is offline   Reply With Quote
The Following User Says Thank You to Bob Sanders For This Useful Post:
Old 01-25-2016, 09:05 AM   #5
Rewards Points: 30
Originally Posted by Bud9051 View Post
Hi phanton,
Bud
Actually Bud , I am in the process of insulating it soon.
Plan on using 1 - 2 inch thick styrofoam on wall with roxul batts between studs. Same for ceiling.
Right now its all concrete with 75% of walls underground.
The ceiling is also cement .
It was an old cellar i plan on transforming into a room.
When i get ready to wire it for baseboards , i was wondering how much should and where should i put them.
Old 01-25-2016, 09:31 AM   #6
WhatRnsdownhill's Avatar
Rewards Points: 2,220
however you configure the baseboards, as a rule on the outside walls, put the thermostat on the opposite side of the room away from the baseboards so it doesnt shut off before the whole room warms up...
WhatRnsdownhill is offline   Reply With Quote
Old 01-25-2016, 09:51 AM   #7
Rewards Points: 3,705
I think your assessment is closer that beenthere's, but it does depend on insulation and climate. I am basing that on this #1 Google page: http://www.kellyelectricalcontractor...ed-for-my-home and on personal experience in USDA zone 6.
I only had one house with full BB heat. For 1000 square feet, typical 40 x 25 ranch, it had 8500 available watts or 8.5 watts per square foot. Insulation factors: floor over crawl r-11, walls r-11 continuous vapor barrier, ceiling 6" of blown fiberglass.
Those suckers could run you out of the house if the spinning of the meter did not make you too dizzy to run.
I personally would try to get one unit centered on each exterior wall with the larger on the larger wall.
Colbyt
Retired drapery and home furnishings installer.
Colbyt is offline   Reply With Quote
Old 01-25-2016, 09:56 AM   #8
what do you have for heat in the rest of the house?
Old 01-25-2016, 10:00 AM   #9
Rewards Points: 30
I have baseboard heaters all over the house. Only source of heat.
I am in Montreal Zone 5b
So i was thinking putting in 3 baseboards of 1000 watts each .
1 on every exterior wall.
Old 01-25-2016, 10:09 AM   #10
electric or hydronic( water filled)? for the rest of the house?
Old 01-25-2016, 10:31 AM   #11
Rewards Points: 30
No Electric baseboard heaters everywhere else.
Old 01-25-2016, 10:35 AM   #12
ok, if you had a main boiler type system you could just tap a new zone..but not in your case...
Old 01-25-2016, 11:13 AM   #13
A scratch pad estimate with no heat above shows about 4,000 btu's at a 10 degree design temp. I suspect less as those walls are mostly below grade and if the space above is heated, way less. No windows or doors to the outside??
1 kw equals 3,412 btus, but that was just a wild estimate. Easy to do a real heat loss estimate.
Although air sealing is typically emphasized to reduce heat loss, it looks like you will have to create some ventilation. You may also want to test for radon in case you want to do anything before you seal it up. Plus, you might be able to merge the ventilation and radon mitigation functions to some degree.
Bud
Old 01-25-2016, 06:25 PM   #14
An old Tradesmen
Do you ever have a week or more of sub 0°F temps.
Whats your frost level.
Old 01-25-2016, 06:50 PM   #15
Rewards Points: 6,694
Do a basic heat loss calc using some software or online, take btus and divide by 3400 to get minimum wattage. The formulas mean nothing.
Not a bad idea to go 10-20% over heat loss at design; no real harm for baseboards.
There are line voltage t-stats out now which will modulate the heat output (well, cycles them very fast to maintain proper heat output) so you don't get them heating up and cooling down all the time, making noise as the metal expands and contracts.
My Backround FIY: I am not in any aspect of the HVAC business now but have formal education + some DIY experience. Theory is not a substitute for experience; neither is "old school" experience an excuse to not understand or practice the theory.
user_12345a is offline   Reply With Quote
Trouble with electric baseboard heaters. djtarnow HVAC 5 02-28-2015 11:16 PM
Electric Baseboard heaters not heating evenly elec_2014 Electrical 11 10-12-2014 01:00 PM
Baseboard heaters and Single Pole / Double pole / two room / four heaters... JPSeattle Electrical 7 04-20-2014 09:20 PM
Wiring 2 baseboard heaters to 1 thermostat AlexandreSauve Electrical 7 04-16-2013 09:22 AM
Electric Baseboard Heaters Always On.. volvik Electrical 15 01-23-2013 02:50 PM
