Piston Size? - HVAC - DIY Chatroom Home Improvement Forum
Old 03-24-2011, 08:30 PM   #1
Rewards Points: 85
piston size?
I have a ADP coil HX8J36D14205
What size piston will work best for a 2.5 ton 10 seer CU?
mikethe ductman is offline   Reply With Quote
Old 03-24-2011, 10:09 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
piston size is based on the outdoor unit. Check installation manual of outdoor unit.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 03-25-2011, 12:49 AM   #3
I'm Your Huckleberry
Rewards Points: 2,270
10 SEER? I know you probably don't want to hear this but nowdays 13 SEER is almost obsolete and 13 SEER is light years head of 10. From what I've been told by a few local insiders, in a few years 16 SEER is going to be the minimum required by the state (Texas) along with an 80% efficiency furnace.
Just a heads up as the time is coming for you to upgrade your entire system, whether you were wanting to or not. Be prepared.
Good luck.
Doc Holliday is offline   Reply With Quote
Old 03-25-2011, 07:05 AM   #4
Low 70's.
Old 03-25-2011, 07:42 AM   #5
An old Tradesmen
Rewards Points: 6,540
ADP would be who you would ask what piston to use. They used a computer simulation to determine what condensers that coil will match to.
The OEM's don't test their condensers to see how they work with third party coils.
Old 03-25-2011, 08:34 AM   #6
I heard the same thing about equipment.The government did it once they can do it again.A 16 seer unit is gonna be good for the business but itll take a while to get your ROI on it.Have to make up a very good value deal on the whole kittnkaboddle! It will go but uncle sams trying to drop the loaD ON OUR GRID.cALIFORNIA AREA IS ONE REASON .tHEY ALLREADY ARE HAVING CONTROLLED BROWNOUTS.
1mastertech is offline   Reply With Quote
Old 03-25-2011, 08:48 AM   #7
The EPA is the one behind it, Montreal Protocal and all that jazz. I heard that the 16 SEER equipment mandate will go into effect on the next code upgrade in the year 2014 or 2016. I'll have to check on that but yes, it's coming.
Size of whole house fan needed Doug Crf General DIY Discussions 20 02-26-2011 12:29 AM
Wiring Size Calculations for New Service CorinthWest Electrical 7 12-07-2010 12:36 PM
Rule of Thumb for Trowel size and Spacer size please.. K.M.G Flooring 7 02-08-2010 09:13 PM
Building a patio cover...span and size of lumber Q's jongordo8 Building & Construction 1 08-30-2009 01:08 AM
pre-hung door, 32x80 is that door size or total size? RyanD Building & Construction 3 06-28-2009 11:33 PM
