Pipe Dope On Unions. - HVAC - DIY Chatroom Home Improvement Forum
Old 10-29-2011, 03:36 PM   #1
Pipe dope on unions.
Had a bit of a debate going on in the plumbing forum, so I was just wondering if any of my fellow HVAC techs use pipe dope on black iron unions for gas? i always thought it was a well known fact that pipe dope should not be used on unions, but it seems like quite a few plumbers do it, which scares me that some would think it's an acceptable practice . What does the HVAC forum think about this?
hvac benny is offline   Reply With Quote
Old 10-29-2011, 03:53 PM   #2
raylo32's Avatar
Rewards Points: 1,294
Interesting topic... I am a DIY and I just replaced my furnace and gas range in the last couple of months. I read here not to put dope on the union surfaces but some said it was OK to put dope on the threaded part of the unions. Imagine my surprise when everything I took apart had dope all over the place including the union surfaces. It even looked like some could have gotten into the gas lines. Oh well, I never had any trouble with anything... but when I put it all back together I did not use dope on the unions and they do not leak.
raylo32 is offline   Reply With Quote
Old 10-29-2011, 04:26 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
I dont put dope on the unions, that is not acceptable practice.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-29-2011, 05:14 PM   #4
REP
You use dope on the pipe connections but not the union surfaces.I have seen dope used on the tightening nut .It dosen't hurt anything but usually not needed..The reason you don't put dope on the union surfaces is because it will get in the way of the machined surfaces and possibly cause a leak.
REP is offline   Reply With Quote
Old 10-29-2011, 07:32 PM   #5
An old Tradesmen
Rewards Points: 8,154
No dope needed on unions.
Old 10-29-2011, 08:57 PM   #6
how
Rewards Points: 1,104
Don't know any professionals who would waste their time doping the mating surfaces of a union. The smallest bit of pipe dope that gets into a gas valve can ruin it. A union that won't seal without pipe dope on the mating surfaces should just be replaced or the two piping sections should be redone to line up correctly with the union(if they aren't already).
how is online now   Reply With Quote
Old 10-30-2011, 06:06 AM   #7
Rewards Points: 1,216
" just say no to dope"
COLDIRON is offline   Reply With Quote
Old 10-30-2011, 06:23 AM   #8
biggles's Avatar
aren't there still GAS unions for natural gas pipe ups only.there is nothing running even in a commercial install that a fitter would use dope on them
Old 10-30-2011, 05:19 PM   #9
I'm a no dope advocate on unions & flared fittings.
VIPlumber is offline   Reply With Quote
Old 10-30-2011, 05:41 PM   #10
I'm Your Huckleberry
Rewards Points: 2,270
In Texas a job will fail if you do not use pipe dope on gas lines or at least I think it will. It is very abundant and mandatory on all jobs concerning gas furnaces. I'd suspect it the same for all gas appliances.
Better safe than sorry, I guess.
Doc Holliday is offline   Reply With Quote
Old 10-30-2011, 06:00 PM   #11
how
Hey Doc
Boy this is a subject with legs. It's right up there with "Should gas lines within a residence be electrically grounded or not?"
I don't think anyone is saying that they wouldn't use dope or tape on gas connections except for this thread on the mating/threaded cinching parts of a union?
Or have I got that wrong?
Old 10-30-2011, 06:09 PM   #12
Doc, there are certain types of gas fittings that work without dope, such as unions and flare fittings. Dope is required, however, where ever you have an MIP-FIP connection.
Old 10-31-2011, 06:35 AM   #13
Doc, were're only talking about the mating surfaces of unions, everthing else gets doped.
How to stop sump pump discharge pipe freezing??? relbeig Plumbing 8 11-12-2012 12:03 PM
Need to close off or move a vent pipe & drain that goes to nothing mystic_cobra Plumbing 2 04-18-2011 08:14 PM
removing Cast Iron drain pipe jimmyfloyd Plumbing 1 01-04-2011 03:47 PM
Exterior Furnace exhaust vent pipe NeedHomeRepair HVAC 1 12-20-2010 05:17 PM
Natural Gas jamiedolan Plumbing 35 09-17-2008 03:57 PM
