#1 |
pipe does not get cold
I don't know the name of the pipe. There is one thin and thick pipe. The thin one gets hot and the thick one I believe is supposed to be cold when the unit is on.
I have about 11 years split system in Dallas. Coil is in the attic and condensor is outside. The pipe used to be cold when A/C was on. When my pipe was nailed by a roofer and fixed last year, I asked the A/C guy why the pipe was not cold any more and he said it'd be still okay. The house was cooling anyway. I survied last year summer with the unit. It still took longer to cool the house though. The temp difference I heard is 15 degree which was excellent per him. This year, the pipe is still not cold and it takes a lot longer to cool the house and I am worried. There is no condensation whatsoever when my the other unit for upstair has condensation and the pipe is very cold. Is it something I should call soemeone to check? The temp difference when outside was 90 was about 12-13 degree in the way I measured. The coil inside was replaced 2 years ago and outside unit is about 11 year old carrier 3.5 ton for 3500 sq house. I have another 4 ton for upstairs as well. what will be the possible causes? |
#2 |
An old Tradesmen
Probably still has a leak, or wasn't charged correctly.
| The Following User Says Thank You to beenthere For This Useful Post: | plummen (04-11-2012) |
#3 |
agree with beenthere still leaking or was not repaired right...have a tech check it out pressures tell alot about a system....
| The Following User Says Thank You to ben's plumbing For This Useful Post: | plummen (04-11-2012) |
| Display Modes | |
| Wood-burning stove...connecting stovepipe to ceiling support box | Laura J. | Building & Construction | 23 | 12-26-2011 01:49 AM |
| cold water reroute outside with pex pipe | staylor7737 | Plumbing | 3 | 07-22-2011 05:56 PM |
| What’s the best way to remove pipe from T | Jaylyn | Plumbing | 2 | 02-03-2011 02:05 AM |
| Hot Water Turning Cold - Could it be the washer/dryer? | kissiffer4 | Plumbing | 3 | 01-28-2010 05:47 PM |
