Old 01-08-2009, 09:20 AM   #1
South Jersey
Pinging/Knocking noise from wall
We just bought a house and have noticed a knocking/pinging noise from the wall when the gas heat turns on and after it turns off it is even louder. I'm prettty sure the vent is a direct run from the heater in the basement thru the wall in the family room (this wall backs to the attached garage) to the bedroom upstairs. From the bedroom it almost sounds like someone is throwing a ball against the side of the house. The noise is louder when the temperature is colder. I'm guessing it is the metal expanding and contracting... anyone know of a fix for this issue?
Thanks Chris
ChrisSNJ is offline   Reply With Quote
Old 01-08-2009, 11:15 PM   #2
JohnH1's Avatar
If you are speaking of a B-Vent flu pipe or also called a double wall chimney. Someone may have screwed the sections together. The inner and outer wall will expand and contract at different rates pulling the screw in and out of the inner wall. This type of pipe should not have screws in it.
Hopfully its something els simpler to correct.
Just a guess.
JohnH1 is offline   Reply With Quote
Old 03-12-2009, 01:23 AM   #3
Chris I'm having the exact same issua you are. I just bought a house and when the heater is on it's like someone is banging on the wall. Did you find out what was wrong with it?
Dany is offline   Reply With Quote
How to diagnose problems with wall kahlan General Discussion 5 10-22-2008 10:18 AM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 05:08 PM
Williams wall furnace whistling noise diyer_mi HVAC 11 10-23-2007 05:05 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
