Old 10-29-2007, 08:39 PM   #1
Pilot won't stay lit on boiler
I have a 9 year old gas fired Utica boiler. The pilot light went out and I am following the directions for re-lighting it, but it won't stay lit. I suspect it may have to do with the metal tube that connects the gas control to the pilot, because when I bought the house a year ago, that tube had been replaced and the old one was lying next to the boiler. Maybe this tube has a short lifespan? Any ideas? If anyone thinks this tube is the problem, any doubts that an amateur could replace it? Our gas company wants $105 for the first 30 minutes, plus parts, so I want to try to repair it myself as long as it isn't too complex.
Thanks for helping out.
Jack
1jackw is offline   Reply With Quote
Old 10-30-2007, 12:57 PM   #2
It seems more likely to be the thermocouple or flame sensor. A 9 year old unit most likely uses a flame sensor.
Do you use natural gas or propane?
delstu is offline   Reply With Quote
Old 10-30-2007, 07:38 PM   #3
I use natural gas...
So I couldn't go without heat for another night (2 small kids and a wife that prefers being toasty), so I paid a plumber to come in, and he replaced the thermocoupling for $150. Nice diagnosis delstu! Thanks for replying.
Jack
More On This Topic
Okay, so the next step is to pull out the broiler pan and look into the boiler and in the very back you will see there is the receptacle or the pilot light assembly. You will simply stick a match up to the pilot light and "poof" the pilot light is lit... Read More »
Types of Stoves
Types of Stoves by Expert Village
So the first thing that you need to do is determine the type of stove you will want. In this situation, we know that it's a gas stove, we have a gas supply, and we're going to...in some cases you may have an electric, in that case you just plug it in... Read More »
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
How to Adjust Fog Lights
How to Adjust Fog Lights by Expert Village
Hi, my name is Nate McCullough on behalf of Expert Village. In these clips we're going to talk about the proper way to diagnose and replace your vehicle's fog lights or accessory lights. In this clip we're going to show you the final step to your fog... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip, I will be talking about locating and replacing your thermostat. The first step to locating your thermostat is to locate the large tubes coming out of your radiator. On this particular car... Read More »
Pilot Light Won't Stay Lit etiger1 HVAC 7 10-19-2009 08:09 PM
Boiler Options -Will Boiler be good enough??!! deano54321 Plumbing 2 10-28-2007 07:18 PM
heat turns pilot light off tclarkmd HVAC 3 10-12-2007 10:37 AM
Pilot Light lits but not stay ourmoney HVAC 15 04-26-2007 08:57 PM
hot pilot light supply line dlkk HVAC 1 02-24-2006 06:45 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
