Pilot Is Lit But Burner Will Not Start On Gas Boiler - HVAC - DIY Chatroom Home Improvement Forum
Old 11-06-2012, 12:18 PM   #1
pilot is lit but burner will not start on gas boiler
How do I fix or troubleshoot problem please any info.
esmith718 is offline   Reply With Quote
Old 11-06-2012, 06:01 PM   #2
An old Tradesmen
Rewards Points: 6,586
Is it a 24 volt control system. if so, do you have 24 volts at the gas valve.
What all have you checked.
Posting brand and model number of the boiler often times helps us help you.
Old 11-06-2012, 06:24 PM   #3
Rewards Points: 582
we need more information than that...is it a standing pilot ...is there 24 volt to stat,valve, ..ben sr
Old 11-07-2012, 07:16 PM   #4
It was the air damper I figured it out it had to be left open so when I started up the pilot the burners could speak then I put it on automatic
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Oil Burner Will Not Start jtslue24 HVAC 3 11-03-2012 03:55 PM
Heil Furnace pilot will not stay on to light burner dwightvines HVAC 12 09-11-2012 07:35 AM
When outside air temps are in 20s or less, Utica boiler "booms" when burner lights. NewDITer HVAC 0 12-14-2010 09:38 AM
utica boiler won't start massman Plumbing 0 01-23-2010 07:26 PM
