Pilot Light Won't Stay Lit - HVAC - DIY Chatroom Home Improvement Forum
Old 04-09-2007, 03:24 PM   #1
I have a Rheem unit model #RGDA-075C-ER. The other day I noticed that the pilot light had gone out, so I spent about 30 minutes trying to get it re-lit. When I pushed in the button the pilot would light but then would go out as soon as I let go. I held it for over 1 minute each time. After doing some reading online, I heard about the thermocoupler. So I went back up and lit the pilot and slowly blew the flame over into the direction that I thought the thermocoupler was located. Believe it or not this worked and the pilot stayed on but for only about 10 seconds after I let go. This was long enough for me to turn the unit on, and it fired up. After the house got to the correct temperature it turned off the unit and the pilot light went out. So does anyone have any ideas? I am wondering if the Thermocoupler just needs to be moved over or adjusted, maybe it is not close enough to the flame. Does this happen? I mean it has worked fine for years now. If you think I need to replace the thermocoupler, please describe where it is located. I have provided a link below to some pictures of the inside of my unit so you know what I have. Also, let me know if it is something that a Home Depot would carry.
Finally, I did have the meter at my outside gas main replaced a few weeks back...so at first I thought that there was just air in the line, however, after the unit ran for 30 mins and I still have the problem I do not think that is it anymore. Also, all of my other gas run items are working fine.
Thanks for any help in advance!
Pictures are at the link below in the HVAC album.
http://www.flipdrive.com/etiger/
etiger1 is offline   Reply With Quote
Old 04-09-2007, 04:28 PM   #2
Great pics.......The unit has a limit hooked to the t-couple and that could mean something but for the time being change the tcouple and remove and clean the pilot......also make sure that the filters are new.
harleyrider is offline   Reply With Quote
Old 04-09-2007, 07:26 PM   #3
Thanks for the response....is the tcoupler something I can get from Home Depot or do I need to go to a HVAC supply store? I assume that I can get the right one by bringing my model # with me.
Old 04-09-2007, 07:31 PM   #4
get a universial 36 ' honeywell, leave any extra coiled up, and DO NOT OVER TIGHTEN....snug and then 1/4 turn at the most.
Old 10-19-2009, 04:33 PM   #5
Pilot stays lit, furnace runs, pilot goes out.
Similar to the previous post, pilot stays lit until the furnace runs. When it reaches temp set on thermostat the system turns off. Aprox 1.5 minutes later the pilot goes out. Is that still a thermocouple issue?
Model: Lennox g12q3-110-3
Installed in May 1984. Yeah, I know - it's old!
glenbailey is offline   Reply With Quote
Old 10-19-2009, 05:29 PM   #6
Rewards Points: 150
If you have not changed the tc since '84, most lkely the problem.
TJ_in_IL is offline   Reply With Quote
Old 10-19-2009, 06:33 PM   #7
You will need to clean that pilot orfice also. If the flame don't reach the thermocouple it won't stay lit.
SKIP4661 is offline   Reply With Quote
Old 10-19-2009, 08:09 PM   #8
Thanks! Looks like I'll be replacing that tomorrow. Nice that they're only $10!
Turning pilot light off jmcs23 HVAC 5 06-17-2007 09:38 PM
Pilot Light lits but not stay ourmoney HVAC 15 04-26-2007 08:57 PM
Can't Light Pilot rsteve12 HVAC 5 02-27-2006 09:35 AM
hot pilot light supply line dlkk HVAC 1 02-24-2006 06:45 PM
pilot light reignition on older williams model Unregistered HVAC 1 02-17-2004 10:26 PM
