Pilot Light Will Not Stay Lit - HVAC - DIY Chatroom Home Improvement Forum
Old 12-01-2008, 08:47 AM   #1
I have an older gas furnace. The pilot light will not stay lit. I replaced the thermocouple and that did not work. Any suggestions? I am a rookie when it comes to furnaces and any feedback would greatly appreciated.
Thanks,
Arete01
arete01 is offline   Reply With Quote
Old 12-01-2008, 09:19 PM   #2
Gas valve or other control problem.
hvaclover is offline   Reply With Quote
Old 12-01-2008, 10:55 PM   #3
The pilot flame has to be clean and impinge on the thermocouple. It can't be a yellow lazy flame. You probably need to clean the pilot burner orifice with a tiny wire. Most thermocouples are replaced because the pilot isn't clean.
hoistdoctor is offline   Reply With Quote
Old 12-02-2008, 04:34 PM   #4
Rewards Points: 109
If you can light the pilot and the flame is hitting the top 1/3 of the thermo and it's a blue flame then when you release the pilot light it goes out you probably have a gas valve gone bad. You also could have overtightened the new themocouple. With a good multimeter you tell if the thermocouple is getting the required heat to activate the magnet. Still thinking valve though.
Daltex is offline   Reply With Quote
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Pilot Light Won't Stay Lit etiger1 HVAC 7 10-19-2009 08:09 PM
Is a pilot light supose to stay on? simonb HVAC 2 06-11-2008 06:16 PM
Pilot light won't stay on judymar General DIY Discussions 28 01-03-2008 07:22 PM
heat turns pilot light off tclarkmd HVAC 3 10-12-2007 10:37 AM
