Old 04-25-2007, 08:18 AM   #1
Pilot Light lits but not stay
hi
we have a Honeywell v4600c boiler.
from yesterday we found its stoped to working when we try to on manually then just pilot light lits but once i leave gas valve its gone down. its not stay.
please can anybody help me please.
thanks.
ourmoney is offline   Reply With Quote
Old 04-25-2007, 02:29 PM   #2
Diesel Fitter
Are you holding the pilot button down till the flame heats the sensor, this may take a full minute or more. If that doesn't work send a message that I can read with all the key words included.
mikemy6 is offline   Reply With Quote
Old 04-25-2007, 02:46 PM   #3
thanks for your reply.
yes i hold it for more then minutes some time two minutes but as soon as i released the pilot button flame gone down. i tried few other things aswell. just holding button and swith high thermostate and switch on water and heater and continusely holding but as i realeased the button same thing happed. what i did today open it and clear the pilot pin and clean the other bit which next to that.
Old 04-25-2007, 02:58 PM   #4
hi and if you can explain me, what is thermocouple? because i was reading some other thread which has got same problem and the mentioned about it so what do you think about
Old 04-25-2007, 03:01 PM   #5
Diesel Fitter
is the other bit a small piece of metal w/a small copper tube going to the pilot /gas control? If so you may be able to replace it if it has a nut holding it to the control valve.Shut the elec. and gas before you do anything! This is the thermocouple and must be replaced W/the same one it keeps the gas valve from opening with no pilot
Old 04-25-2007, 03:09 PM   #6
Diesel Fitter
real qwick its a sealed tube builds pressure as its heated this is what is sensed in the control if you loss the seal it wont work
Old 04-25-2007, 03:11 PM   #7
is it the next to flame? when the pilot lit its become to red. are you talking about that bit? are you thinking is that solve this problem?
thanks.
Old 04-25-2007, 03:13 PM   #8
yes now i understand. where can i get this bit?
Old 04-25-2007, 03:13 PM   #9
have you got idea baout price?
Old 04-25-2007, 03:19 PM   #10
Diesel Fitter
try home depot or a local plumming supply place but this Im not sure of try the computer or phone I gotta run but could make a call when I get back within the hour
good luck
Old 04-25-2007, 03:19 PM   #11
Diesel Fitter
cheap
Old 04-25-2007, 04:09 PM   #12
Diesel Fitter
called both and they both said they carry them just be careful on the install so you dont kink the new one
Old 04-25-2007, 04:14 PM   #13
thanks mate
if you could make a call then it will be much appriciated. i opened again and i checked thermocouple, will i have to detatch the whole parts which looks like a copper pipe or just a that bit? if its just the bit then how?
thanks again.
Old 04-25-2007, 04:33 PM   #14
Diesel Fitter
it should be a very small copper tube looks like a coiled up wire where it goes into the control it should go thru the center of a nut about 1/4 to 3/8 inch the bit (bulb) side should only be held next to the pilot W/ a screw just note the position of the bulb upon removal cause you want it to go back in the same spot.dont rip out the metal hanger at the pilot
Old 04-26-2007, 06:25 PM   #15
thanks mate. i have replaced today and its working now.
Pilot Light Won't Stay Lit etiger1 HVAC 7 10-19-2009 08:09 PM
Turning pilot light off jmcs23 HVAC 5 06-17-2007 09:38 PM
Can't Light Pilot rsteve12 HVAC 5 02-27-2006 09:35 AM
hot pilot light supply line dlkk HVAC 1 02-24-2006 06:45 PM
pilot light reignition on older williams model Unregistered HVAC 1 02-17-2004 10:26 PM
