Pilot Light Going Out Often...and Furnace Making A Big "boom" Sound - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-07-2009, 05:17 PM   #16
An old Tradesmen
Rewards Points: 6,112
You can use either.
I prefer to use high temp gasket material with the caulk.
But, it is expensive.
Old 01-07-2009, 08:46 PM   #17
Rewards Points: 562
Anything is possible. I used to live where the furnace banged when lighting too,,,but never blew out the pilot. When looking at the furnace burning,,,not all the burners were burning outside where they belonged. Some were burning inside the burner tubes. Propane guy fixed it one time,,,but quickly did same thing. Said it wasnt to be worried about,no problem. my guess is it was old enough they burned thru and rusted out. basement had standing water in it alot of the year
4just1don is offline   Reply With Quote
Old 01-12-2009, 12:39 PM   #18
Re: Furnace Problem
Here is the latest, I've removed my new heat cells to seal them with high temp sealant. One of the cells did seem to be loose so I made sure they were all very tight and well seated against the manifold. When I returned the unit to service It starts up fine with the cover off. When I put the cover on and seal it up correctly I then get a tripped rollout switch on startup and I have to manually reset it. Seems like this is where it all started. I also remembered using one of those new allergy filters this summer that has the fabric type filter material( or whatever you call it) Vs. the inexpensive fiberglass filter that I used to use. I found that this restricts the air flow through my return a good bit. I'm thinking that maybe this is where it all began. I'm going to replace the roll out switch today since it has been activated so many times by now. If this doesn't get it then I think maybe the gas valve may need to be adjusted. I've replace the heat cells, cleaned the burners and the spark ignitor rod, and replaced the ingnitor box, which still seems to be okay even though the cover has melted a little. ( I still get the heartbeat or pulsing green light and it operates okay so I think its okay) Other than that every thing cycles as normal, it's just tripping the flame rollout switch at start up. Thanks for any comments on this issue
plunked is offline   Reply With Quote
Old 01-22-2011, 04:39 PM   #19
Fireguy,
I'm having a similar problem with a commercial Southbend Range, the right oven pilot light stays lit. But I noticed that it's making a boom, I assume from gas filling up in the oven, but not igniting. Do you have any advice on what you think it might be since you mentioned you work on commercial appliances. I've been watching it to see if I can figure out what is wrong. The left oven has no problem. Thanks for anyhelp.
zaskar is offline   Reply With Quote
Old 01-22-2011, 04:58 PM   #20
Originally Posted by zaskar View Post
Fireguy,
Old thread guy.
Post a new thread or no one will find you here.
Good Luck
hvaclover is offline   Reply With Quote
Old 01-22-2011, 05:27 PM   #21
One thing for sure is the pilot flame needs to be tall enough and real close to the first burner or supply line outlet to all burners. For sure and for some reason. the gas flow inputted is not hitting the pilot immediately. possibly the gas is being sucked up by an attic fan, vent fan, AC or Heater. I have seen some that when the main burner comes on the line pressure drops and the pilot goes almost out. Check that also.
look fer it!
jehiatt is offline   Reply With Quote
