Pilot Light Goes Out - HVAC - DIY Chatroom Home Improvement Forum
Old 12-03-2009, 01:43 PM   #1
pilot light goes out
hi -i have an older american standard(over 30 years) and about 2 weeks ago the pilot started going out.after replacing the thermal coupling and my plumber doing different things it was decided i needed a new gas valve.however,
before i did this (and after lighting 20 times a day) i discovered that if the little access door to light the pilot was left off the pilot never went and as soon as i put the door back on the pilot would blow out after the heating cycle.i am
now looking at new furnaces because i don't want to go on and on.the "new" furnace estimator said his guess would be a slight crack in the heat exchanger--any ideas --thanks daryl
darylw is offline   Reply With Quote
Old 12-03-2009, 06:09 PM   #2
Good possibility a crack is the issue. Does the pilot blow out if you turn the fan on? At 30+ years of age it's almost always a good idea to cut you losses and start over. The fuel saving alone will pay for the furnace many times over.
Old 12-03-2009, 06:21 PM   #3
thanks for the response-no it goes out after the cycle when the flame lowers to onlyl the pilot . i think you're right about just going to a new one.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 04:19 PM
Is a pilot light supose to stay on? simonb HVAC 2 06-11-2008 05:16 PM
heat turns pilot light off tclarkmd HVAC 3 10-12-2007 09:37 AM
hot pilot light supply line dlkk HVAC 1 02-24-2006 05:45 PM
