Old 07-16-2006, 06:10 PM   #1
pilot light goes out
i have a old gas furnace.pilot light goes out about once a week.always relights fine.any suggestions?
thanks aaron
jepthng is offline   Reply With Quote
Old 07-16-2006, 06:19 PM   #2
Home Improvement Guy
ron schenker's Avatar
Does it happen during a very windy day? Could be a backdraft from the metal chimney up on the roof. A strong wind at just the right pressure and direction could cause the pilot light to go out.
ron schenker is offline   Reply With Quote
Old 07-16-2006, 07:02 PM   #3
Years ago I use to have to replace the thermal couple on this heater we had.I had to replace it about every four or five years.
It was pretty easy to replace.
I can not remember if the pilot would stay lit for a bit at all or not.
Doug Crf is offline   Reply With Quote
Old 07-16-2006, 08:03 PM   #4
Is the pilot strong or does it flicker?
If it flickers then it may have debris in the tube. Turn off the pilot light gas valve (or the main gas valve for the furnace) and then remove the pilot light gas tube. Blow some compressed air thru it and see if any blockage comes out. Reconnect and see it that helps.
If the pilot light is strong then you may need a chimney cap to keep down drafts from blowing out the pilot light.
redline is offline   Reply With Quote
Pilot Light Won't Stay Lit etiger1 HVAC 7 10-19-2009 08:09 PM
Turning pilot light off jmcs23 HVAC 5 06-17-2007 09:38 PM
Can't Light Pilot rsteve12 HVAC 5 02-27-2006 09:35 AM
hot pilot light supply line dlkk HVAC 1 02-24-2006 06:45 PM
pilot light reignition on older williams model Unregistered HVAC 1 02-17-2004 10:26 PM
