Old 12-09-2011, 07:42 PM   #1
FPS
Pilot Light goes off
Propane heater. I light the pilot and turn the gas valve to ON position. When I turn up stat to fire the heater the pilot light goes off.
This is a new gas valve and pilot generator. Heater did the same thing with old parts.
FPS is offline   Reply With Quote
Old 12-09-2011, 07:48 PM   #2
biggles's Avatar
millivolt pilot generator setup.... 2 wire thermostat...are you holdning down the gas valve dialin PILOT position then letting it up after 30secs pilot should stay lit then move valve to ON position...have stat in off position before doing anything
Old 12-10-2011, 08:18 PM   #3
retired elect/hvac/plumb
plummen's Avatar
is blower running,does furnace make loud noise like a boom when fires up ?
plummen is offline   Reply With Quote
How to diagnose gas valve problems Nestor_Kelebay How To Guides 27 03-07-2013 03:17 AM
Williams NG furnace pilot light will not stay lit zBernie HVAC 1 12-04-2011 11:06 PM
single pole switch with pilot light tsc2011 Electrical 8 11-29-2011 08:50 AM
Pilot Light works once, then have to re-light after furnace goes off aransas42 HVAC 8 09-30-2009 08:49 AM
Is a pilot light supose to stay on? simonb HVAC 2 06-11-2008 06:16 PM
