Pilot Light Flame Won't Reach Thermocouple - HVAC - DIY Chatroom Home Improvement Forum
Old 10-11-2012, 07:32 PM   #1
Pilot light flame won't reach thermocouple
My heatilator fireplace pilot light will ignite while I hold in the switch, but the flame will not extend far enough to heat and activate the thermocouple. I lit the pilot and used a butane lighter to heat the thermocouple at the same time and it worked when I released the switch so the thermocouple is working. However, when I take away the lighter it cools quickly and shuts off the gas supply. I suspect spider webs in the gas supply tube that reduce the gas pressure as the flame has a lot of yellow in it. There is a tri-cornered cap on top of the gas supply tube that directs the flame to the thermocouple and the main flame. How do I safely remove the cap to clean the tube as it has a sleeve that seems to go to the bottom where the tube comes into the firebox and it will not slide off with a moderate tug?
Geranium is offline   Reply With Quote
Old 10-11-2012, 08:01 PM   #2
Rewards Points: 582
well we would need a picture ....but you have to clean pilot tube and orifice to improve pilot.....
Old 10-11-2012, 09:10 PM   #3
how
Rewards Points: 1,104
Usually you need to remove the whole pilot assy to take apart and access the pilot orifice.
It doesn't help with spider webs but often rapping the metal base of the pilot assy with a screwdriver while the pilot gas is flowing will dislodge pilot orifice debris. (Don't hit the igniter porcelin or your repair job will suddenly become more complex)
how is offline   Reply With Quote
new napoleon vent free lp fireplace won't light from the pilot light jr6006 HVAC 6 11-08-2011 10:56 PM
Pilot light lit, but wont light the rest Dangldn HVAC 3 10-26-2011 08:43 PM
Fixed pilot light, now furnace or AC won't turn on mjcfromct HVAC 2 10-17-2011 11:46 PM
Pilot Light works once, then have to re-light after furnace goes off aransas42 HVAC 8 09-30-2009 08:49 AM
hot pilot light supply line dlkk HVAC 1 02-24-2006 06:45 PM
