02-12-2010, 10:28 AM
#2
Pilot light does not stay on
I'd wait for an HVAC guy to reply but rest easy for now, I think it is just the thermocouple. Cheap and easy to replace.
02-12-2010, 11:24 AM
#3
An old Tradesmen
Could be bad thermocouple.
Bad gas valve.
Tripped roll out switch.
Or a tripped ECO, in which case the gas valve still needs changed out.
Looks like thermostat is turned all the way up.
02-12-2010, 11:50 PM
#4
Bad gas valve.
I pulled out the thermocouple and planning to replace it tomorrow with a new one. If this is not the problem, what is tripped roll out switch and/or tripped ECO.
Yes. In the picture, thermostat is all the way up.
02-12-2010, 11:53 PM
#5
An old Tradesmen
Your last pic has the roll out switch.
ECO is part of the gas valve/thermostat assembly on most water heaters, and not resettable.
02-13-2010, 10:34 AM
#6
How do I reset the roll out switch. I want to try this first before buying a new thermocouple.. Can you please let me know ?
02-13-2010, 03:32 PM
#7
An old Tradesmen
Push the button in the middle of it. If it resets, then you know you have a problem that caused it to trip, and need to find out what that is.
Could be a restricted chimney.
02-13-2010, 05:45 PM
#8
I tired to push the block knob but it does not really go in.. what does that mean ?
02-13-2010, 06:06 PM
#9
An old Tradesmen
Its probably not your roll out then.
Could be gas valve, thermocouple, or ECO(emergency cut out).
Do you have a meter to test anything.
02-13-2010, 07:27 PM
#10
No, I don't have any meter to test.. I will go ahead and get a new thermocouple.. I will let you know then..
02-14-2010, 02:34 PM
#11
I put the new thermocouple but it still does not work.. I tried 3 times, pilot gets on but does not stay once I release the button.
02-14-2010, 06:38 PM
#12
An old Tradesmen
Could be the valve or ECO. If its the ECO, you still need a new valve.
With out meters to test things. Can't tell you anymore to do.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
