-   -   Pilot light does not stay on (http://www.diychatroom.com/f17/pilot-light-does-not-stay-64238/)
cprao 02-12-2010 09:14 AM
I have 2005 Bradford Defender gas water heater. I am facing the problem with not getting hot water at all.
http://i699.photobucket.com/albums/v...r/P2060042.jpg
http://i699.photobucket.com/albums/v...r/P2060043.jpg
http://i699.photobucket.com/albums/v...r/P2060044.jpg
http://i699.photobucket.com/albums/v...r/P2060045.jpg
http://i699.photobucket.com/albums/v...r/P2080047.jpg
Following the instructions I could light the pilot but the light does not stay on.
Instructions says - I need to hold the pilot set button for a minute and the pilot light should stay on even after releasing the button.
In my case, as long as I hold the button (almost 2 minutes), the pilot light stays on but the moment I release the button, pilot light goes off..
What would be my next step from here ? Any clue ? Since the pilot light is coming what I conclude is - 1) My ignitor is working and 2)gas is coming to the appliance.. Now what can be wrong here ? what should I be checking next ? Please help
daveb1 02-12-2010 09:28 AM
I'd wait for an HVAC guy to reply but rest easy for now, I think it is just the thermocouple. Cheap and easy to replace.
beenthere 02-12-2010 10:24 AM
Could be bad thermocouple.
Bad gas valve.
Tripped roll out switch.
Or a tripped ECO, in which case the gas valve still needs changed out.
Looks like thermostat is turned all the way up.
cprao 02-12-2010 10:50 PM
Bad gas valve.
I pulled out the thermocouple and planning to replace it tomorrow with a new one. If this is not the problem, what is tripped roll out switch and/or tripped ECO.
Yes. In the picture, thermostat is all the way up.
beenthere 02-12-2010 10:53 PM
Your last pic has the roll out switch.
ECO is part of the gas valve/thermostat assembly on most water heaters, and not resettable.
cprao 02-13-2010 09:34 AM
How do I reset the roll out switch. I want to try this first before buying a new thermocouple.. Can you please let me know ?
beenthere 02-13-2010 02:32 PM
Push the button in the middle of it. If it resets, then you know you have a problem that caused it to trip, and need to find out what that is.
Could be a restricted chimney.
cprao 02-13-2010 04:45 PM
I tired to push the block knob but it does not really go in.. what does that mean ?
beenthere 02-13-2010 05:06 PM
Its probably not your roll out then.
Could be gas valve, thermocouple, or ECO(emergency cut out).
Do you have a meter to test anything.
cprao 02-13-2010 06:27 PM
No, I don't have any meter to test.. I will go ahead and get a new thermocouple.. I will let you know then..
cprao 02-14-2010 01:34 PM
I put the new thermocouple but it still does not work.. I tried 3 times, pilot gets on but does not stay once I release the button.
beenthere 02-14-2010 05:38 PM
Could be the valve or ECO. If its the ECO, you still need a new valve.
With out meters to test things. Can't tell you anymore to do.
