Pilot Light Confusion Please Help - HVAC - DIY Chatroom Home Improvement Forum
Old 10-04-2008, 10:38 AM   #1
Question
pilot light confusion please help
Hello there I have an old furance with a standing pilot light but i doint understand why my pilot light goes out when i turn up the upstairs thermostat. The thermostat clicks like its ready but when i go back to the furance the pilot is out. As well when i turn the blower fan switch to on the fan does not come on. Any suggestions, Thks.
fastcarsca1 is offline   Reply With Quote
Old 10-04-2008, 10:45 AM   #2
Get a bottle brush and clean off the area around the pilot light. This might be the problem. When the furnace fires up the "poof" if igniting gas blows out the pilot light and then thermocouple shuts off the gas.
I just had one like this last spring.
If not then there might be a problem with the thermocouple. I see this sometimes when they are going out.
Marvin Gardens is offline   Reply With Quote
Old 10-04-2008, 10:52 AM   #3
thks
ok I will try that thks but it seems like there is no poof the pilot light just slowly dies out and without being able to turn the blower fan on manually was also thing maby a power problum.
Old 10-04-2008, 11:44 AM   #4
Then replace your thermocouple. It is cheap and easy to do. If that works then you are good to go. It is doesn't then time to call a professional (or get lots of blankets).
Old 10-04-2008, 02:44 PM   #5
Electrician
SD515's Avatar
Rewards Points: 504
I agree with Marvin. Try a new thermocouple. Heating a thermocouple creates it's own small amount of voltage, which holds open the pilot valve section of the gas valve. It is totally independent of the 120V supplying the furnace from the house. Standing pilots need no external electricity.
The fact of not being able to turn on the blower fan at the t-stat is a completely separate problem. The stat may be bad, or not wired correctly. Many furnaces that do not have AC (heat only) are only wired with a 2 conductor t-stat cable. A third is needed to be able to use the blower in manual mode. There also may be other electrical issues with in the furnace itself.
Kyle
Wiring diagram for three-way switches with pilot light SaxTeacher Electrical 34 09-15-2013 07:53 AM
Pilot Light Won't Stay Lit etiger1 HVAC 7 10-19-2009 07:09 PM
Is a pilot light supose to stay on? simonb HVAC 2 06-11-2008 05:16 PM
heat turns pilot light off tclarkmd HVAC 3 10-12-2007 09:37 AM
hot pilot light supply line dlkk HVAC 1 02-24-2006 05:45 PM
