-   -   Pilot light on boiler is on but won't flare up! (http://www.diychatroom.com/f17/pilot-light-boiler-but-wont-flare-up-29521/)
SingleMom 10-07-2008 10:41 AM
Hello All,
I went to turn on my boiler last night and it wouldn't start. I had to rpelace the batteries in the thermostat upstairs because the digital reading wouldn't stay on. after replacing the batteries, the thermostat worked fine. Would this have anything to do with the boiler not flaring up? I looked under the boiler and the pilot light is on. However, last year I have to constantly add water to my boiler becuase it keeps going below the water leavel and turning off. The water level valve is a bit rusted, but I can see the water level. Thansk for any advise.
SingleMOM
hvaclover 10-07-2008 04:50 PM
A boiler is something that you should not mess with.
I would suggest an automatic water make up control.
If your water is low than your low water cutoff is probably opened. It's a safety to stop the boiler from causing a deadly accident.
