Pilot Keeps Blowing Out - HVAC - DIY Chatroom Home Improvement Forum
Old 10-08-2011, 12:44 PM   #1
pilot keeps blowing out
my gas furnace has a draft of air comming from the ventalation pipe from out side ant it keeps bloing the pilot flame out what can i do to fix this?
john j lujan is offline   Reply With Quote
Old 10-08-2011, 01:05 PM   #2
Ventilation pipe, as in combustion air supply, or do you mean the exhaust?
hvac benny is offline   Reply With Quote
Old 10-08-2011, 01:10 PM   #3
i think it is the exaust but not sure
Old 10-08-2011, 01:18 PM   #4
i think it is the exaust the re is only one pipe that goes outside right behind the wall mounted furnace...
Old 10-08-2011, 02:06 PM   #5
biggles's Avatar
if it's not windy out side or a lit match doesnt blow out held up to the burner section might be a weak thermo couple....not holding the pilot relite
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 10:40 AM
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Older Carrier Pilot Burner Problem cliffkot HVAC 23 04-29-2011 05:58 PM
Urgent! House Cold, NO heat, pilot lit (Lennox) ThatGuy23 HVAC 15 02-05-2009 09:11 PM
heat turns pilot light off tclarkmd HVAC 3 10-12-2007 09:37 AM
