Pilot On Furnace Burner Wont Ignite - HVAC - DIY Chatroom Home Improvement Forum
Old 02-27-2013, 01:21 AM   #1
pilot on furnace burner wont ignite
my furnance pilot is on but burners wont ignite con anyone help me with this problem
antmay is offline   Reply With Quote
Old 02-27-2013, 01:35 AM   #2
Rewards Points: 99
Need a lot more info before giving any idea as to the problem.
1. Is the furnace standing pilot or spark ignition
or hot surface ignition?
2. What is the maker of the furnace?
3. Did you try jumping R and W at the furnace or stat subase?
4. Do you have 24 volts at the gas valve when calling for heat?
kirwinjd is offline   Reply With Quote
Old 02-27-2013, 01:35 AM   #3
how
Rewards Points: 1,070
make & model of the furnace helps. Pic's with doors removed even better.
Pilot is on with no main gas burning with a call for heat.
Is the gas valve getting 24 Volts?
Is the power on to the furnace? (On/ off switches, fan blower door switch, breaker blown?)
Is there 24 V coming from the transformer?
Is your thermostat really working? (remove stat wires from thermostat and cross them )
Is there a fuse in line with the 24V side of the transformer & is it good?
Have you tripped limits or roll out switches.
how is offline   Reply With Quote
Old 02-27-2013, 10:20 AM   #4
Roofmaster
Rewards Points: 2,172
Change the batteries in your thermostat.
Pilot burner replacement - Carrier 58GS150-CB furnace danielr HVAC 11 02-08-2013 01:19 PM
Fixed pilot light, now furnace or AC won't turn on mjcfromct HVAC 2 10-17-2011 11:46 PM
Pilot light going out often...and furnace making a big "boom" sound Beth777 HVAC 20 01-22-2011 05:27 PM
pilot lit, burner won't ignite unless I blow on pilot light rl5 HVAC 7 01-06-2011 10:08 PM
Urgent! House Cold, NO heat, pilot lit (Lennox) ThatGuy23 HVAC 15 02-05-2009 10:11 PM
