Pilot Flame...too Big? - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-16-2009, 08:44 AM   #16
An old Tradesmen
Rewards Points: 6,470
G6 pilot assmbly, I think.
Old 04-16-2009, 10:58 AM   #17
HVAC / Plumbing
Can't picture the 1 you are talking about.. This is the 1 I was thinking of
kenmac is offline   Reply With Quote
Old 04-16-2009, 11:00 AM   #18
An old Tradesmen
I'm thinking of an older one yet.
Just showing my age a little I guess. oops. LOL
Old 04-16-2009, 11:03 AM   #19
If it's spark then that's the one.
Only other kind was a two wire assy
hvaclover is offline   Reply With Quote
Old 04-16-2009, 11:11 AM   #20
That's the one. In fact, that picture is from the website where I ordered my replacement.
timcoon is offline   Reply With Quote
Old 04-16-2009, 11:15 AM   #21
HVAC / Plumbing
I think That one had a small coil that heats up red hot to light pilot & some had a spark..can't remember which had wihich haven't seen these in a while. For some reason, I still carry 1 on my truck .Old bi metal stuff.. You can probably re- use your old pilot tubing
Old 04-16-2009, 11:26 AM   #22
Thanks, kenmac. Mine has the spark ignitor, which I also got a replacement for. I'm sure that would go next, so I figured better have it just in case.
I guess I should consider myself lucky, this thing has been running like a trooper for quite a while now. We just started the "furnace replacement fund"...I hope it's "funded" before I need it!
Old 04-16-2009, 12:10 PM   #23
Hvac Pro
yuri's Avatar
Rewards Points: 1,412
Make sure you have 2 newer good quality CO detectors in your house. One near your bedroom and the other in the furnace room or stairwell leading upstairs. Heat exchangers can crack at any time after 20 yrs or sooner for some brands.
Old 04-16-2009, 12:44 PM   #24
HEY PROS!Just curious how you troubleshoot this assy to make sure its not the valve.
I use my volt meter plugged into the pilot and main burner receptacle in the assy wire harness and let the pilot burn long enough 'til the bi metal either drops out of main burner. I f it does not drop main burner after twenty minutes I call it the pilot assy..
How about you guys?
Old 04-16-2009, 01:21 PM   #25
HVAC / Plumbing
I use my volt meter plugged into the pilot and main burner receptacle in the assy wire harness and let the pilot burn long enough 'til the bi metal either drops out of main burner. I f it does not drop main burner after twenty minutes I call it the valve.
How about you guys?
I'am by far a ''PRO'' But, I'll give it a shot.....I would un plug the pilot, connect my meter to the bi metal connection wire & what would be the Power wire. set to ohms scale. If bi metal has made up it should show contiuity between the voltage wire & what I would call the common wire or bi metal wire...I say it's the valve
Provided ,I have correct voltage in the correct placed
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
How to diagnose gas valve problems Nestor_Kelebay How To Guides 28 10-30-2013 05:19 PM
Urgent! House Cold, NO heat, pilot lit (Lennox) ThatGuy23 HVAC 15 02-05-2009 10:11 PM
Utica Boiler Pilot light on but will not flame up! MGB150HID HVAC 2 12-10-2007 05:48 PM
heat turns pilot light off tclarkmd HVAC 3 10-12-2007 10:37 AM
