Pilot Doesn't Stay Lit - HVAC - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 04:26 PM   #1
Rewards Points: 20
Pilot doesn't stay lit
i have an old WIlliams Wall Heater.
I push the brown BUTTON when its in the PILOT position and light the pilot. I hear the gas flowing from the pilot thing and put my light near by - the pilot lights. When I then try to rotate the BUTTON to the
ON position, the pilot light goes out. I tried keeping the flame on in PILOT position for an extended period in case the heating element needed a long time to warm up -- still no luck. Please keep in mind the the Thermostat is in the maximum heat position (90+).
Any suggestions? is there a part I can replace myself? should i leav it to a pro? how much would it cost to fix?
thanks in advance. larry
avatar2k is offline   Reply With Quote
Old 01-03-2011, 04:37 PM   #2
Rewards Points: 20
Model Number
the model n umber is: C35 SD
Old 01-03-2011, 05:04 PM   #3
Rewards Points: 20
Please see attached pic of lit pilot...
Old 12-07-2015, 11:18 PM   #4
Rewards Points: 20
Nobody ever answered my question... :-(
How hard is it to replace the gas valve? I replaced the thermocouple and still no luck.
Old 12-07-2015, 11:26 PM   #5
Rewards Points: 8,206
Could it be a dirty pilot orifice? is the flame totally engulfing the thermocouple.
Does the flame get extinguished as soon as you stop holding the button?
My Backround FIY: I am not in the business of any trade or topic I give advise on. I have some have formal education in HVAC + some DIY experience. Theory is not a substitute for experience.
user_12345a is offline   Reply With Quote
Old 12-07-2015, 11:30 PM   #6
Rewards Points: 214
See if some of the similar threads down at the bottom of the page help. I'm no expert on this, just on unconscious pattern recognition :}
Nik333 is online now   Reply With Quote
Old 12-07-2015, 11:31 PM   #7
Rewards Points: 20
Hello!! thank you so much for your reply. Let me try to answer your questions:
1. yes, the pilot flame totally engulfs the thermocouple. I actually made sure the pilot flame had time to heat the thermocouple up a lot by continuing to push the pilot button 1- 2 minutes BEFORE I tried to rotate the pilot button to the "ON" position.
2. Yes- as soon as i try to rotate the button to the "ON" position the pilot flame goes out.
thanks!
Old 12-07-2015, 11:48 PM   #8
Turn down the t-stat all the way when you try.
If the pilot stays lit when in pilot position and not being pushed down, yet goes out when you rotate the knob to on my guess would be a bad gas valve.
there may be a way to check the voltage output of the thermocouple or power pile, whichever it is.
this is all based on what i know, not experience with wall heaters. i've never seen one, but same concept as a gas fireplace or water heater.
Old 12-08-2015, 04:07 AM   #9
An old Tradesmen
Rewards Points: 8,168
How easy it is to change the gas valve varies with how easy it is to get to.
Not familiar with your Brand, so can't say how easy it will or won't be.
Old 12-08-2015, 05:46 AM   #10
Rewards Points: 3,952
What's pilot gas pressure? Have you removed and cleaned the pilot assembly?
roughneck is offline   Reply With Quote
Old 12-08-2015, 07:51 AM   #11
Rewards Points: 20
roughneck: don't know what the pilot gas pressure is but the pilot flame is substantial when its lit (please see the picture posted on this thread above). How do I check the pilot gas pressure?
I have not cleaned the pilot assembly - how do I do that? thanks!
Old 12-08-2015, 07:54 AM   #12
Rewards Points: 20
user_12345a: i check the thermocouple with a voltage meter by applying fire to the tip and checking the leads for current. I bought a new thermocouple and it seems to be working fine.
Old 12-08-2015, 11:21 AM   #13
Rewards Points: 20
... the fact that the thermocouple seems to be working (and is new) leads me to believe the problem may lay with the gas valve. Does that make sense?
Old 12-08-2015, 03:22 PM   #14
An old Tradesmen
Very well could be the gas valve.
Pilot on Williams millivolt wall heater goes out every 8 to 16 hours wornways HVAC 30 06-22-2011 03:29 PM
Pilot light does not stay on cprao HVAC 11 02-14-2010 05:38 PM
Pilot Light Won't Stay Lit etiger1 HVAC 7 10-19-2009 07:09 PM
Is a pilot light supose to stay on? simonb HVAC 2 06-11-2008 05:16 PM
Pilot light won't stay on judymar General DIY Discussions 28 01-03-2008 06:22 PM
