Pilot On Burners Do Not Light Up Weill McClain EGH 95 - HVAC - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 10:04 PM   #1
Angry
Pilot on burners do not light up Weill McClain EGH 95
The pilot light is on the on position and is lit. However the burners do not light up. I checked the settings on the Aquastat they look good. the reset button on the Honeywell will not reset. I tried checking for the fuse but do not where it is located
eyesicon is offline   Reply With Quote
Old 01-14-2013, 10:23 PM   #2
It sounds like you have an older furnace, most older furnaces don't have a 3 amp fuse. Did you check for power to the furnace? Try to plug something in the outlet to see if it has power. If it has power, then you need to check the transformer for 24v. Try to reset the roll out switches. A roll out switch should have a button for you to reset. Here is a picture of the roll out switch
http://www.appliancezone.com/ShowProduct.aspx?ID=6776
if you press the roll-out switch and the furnace turns on, then you might have overheating problems.
Mr.HVAC is offline   Reply With Quote
Old 01-14-2013, 10:32 PM   #3
I thought there was a fuse. the Furnace is gas and it is about 3 years old. I do not think it is over heating. It seems to be something that has a cutfoff
Old 01-14-2013, 10:37 PM   #4
eyesicon,
you sure the furnace is 3 years old? cause for a furnace to have a pilot light, it must be way older than that. Can you post the brand name, model and serial #. and when you said lit, is it lit all the time?
Old 01-14-2013, 10:43 PM   #5
eyesicon,
I just read the title again. It looks like you have a boiler system. Sorry, I am going to let someone else take over because I have little experiences with boiler. My apology
Old 01-14-2013, 10:46 PM   #6
It is an EGH 95 series number 4. CSA Gross Output 400,000 water 50 psi. Thank you Mr. HVAC I appreciate your attempt to help this soon to be cold person.
Old 01-14-2013, 10:48 PM   #7
I have put a series of pictures 3. The album is "Weill McClain under the Hood". Those photos will show the wiring for the burners etc.
Old 02-04-2013, 11:54 AM   #8
The problem was the Guard dog on the furnace. We changed it and burners kicked in and started working
Old 02-04-2013, 01:49 PM   #9
Rewards Points: 1,300
Thanks for coming back and filling us in. Good to hear you got it going.
danpik is offline   Reply With Quote
Tags
boiler repairs , hvac help
Rheem 40gal water heater - Pilot won't stay light...thoughts ? anku HVAC 10 05-26-2013 02:55 AM
Pilot light won't light BarryBe HVAC 3 05-22-2011 11:05 AM
Heil Furnace Pilot Light Not Igniting shwank HVAC 13 10-07-2010 06:41 AM
Pilot Light for A.O. Smith model GVC 4100 Pojono Plumbing 1 09-26-2010 08:01 PM
hot pilot light supply line dlkk HVAC 1 02-24-2006 05:45 PM
