Picking A Programmable Thermostat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-14-2011, 09:35 AM   #1
Rewards Points: 157
Picking a programmable thermostat
Dear experts,
I need to replace my thermostat with a programmable one. I have a boiler, and no AC. Could you please recommend something not too expensive, but reliable?
Thanks in advance.
dpreznik is offline   Reply With Quote
Old 10-14-2011, 05:47 PM   #2
biggles's Avatar
so you have 2 low voltage wires to the exsisting one..and its 24Vs not line 115V like a light switch wire size
Old 10-15-2011, 07:49 AM   #3
AKA HVACTECHFW
Rewards Points: 1,208
we do need to know this information as Biggles asked. What thermostat are you currently using? Just an old Honeywell YO-YO? Can you post a picture?
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-15-2011, 07:36 PM   #4
Rewards Points: 157
I don't know the details of the thermostat inside. I have attached a picture.
Thanks.
Old 10-15-2011, 07:48 PM   #5
biggles's Avatar
thats a T87 2 wire 24V straight heating stat no switching.HD or Lowes has a bunch you can just replace that with keep it simple don't go to much with bells and whistles or the installl is going to call for the infamous C wire off the transformer to power it up...keep that in mind.hopefully you can do times programming with a 2 wire feed back set up as you have and note it to the people you buy it from at the home center check here for types you oculd get any programmable but if it calls for the C wire $$$ to add one http://www.bestbuyheatingandaircondi...ostatsmenu.htm
The Following User Says Thank You to biggles For This Useful Post:
dpreznik (10-15-2011)
Old 10-15-2011, 08:23 PM   #6
Rewards Points: 157
Thank you very much for your answer. The link you provided contains multiple thermostats, and I am not sure which one to pick.
Old 10-15-2011, 09:09 PM   #7
AKA HVACTECHFW
for a DECENT programmable all you need is a RTH6350D or better.
IT IS WHAT IT IS
The Following User Says Thank You to hvactech126 For This Useful Post:
Old 10-15-2011, 09:10 PM   #8
biggles's Avatar
that was just a visuale,but you need to hit the home improvement centers and tell they what you have what type of heat furnace boiler baseboard heat they need to know it...with a 2-wire stat honeywell T87 heat only no subbase switching
Old 10-16-2011, 11:35 AM   #9
Rewards Points: 157
So RTH7400D will do?
Old 10-16-2011, 11:37 AM   #10
AKA HVACTECHFW
yes, it will work
IT IS WHAT IT IS
dpreznik (10-16-2011)
Help Wiring Programmable Thermostat Brio9 HVAC 4 02-14-2011 12:25 AM
programmable thermostat and quadr fire pellet stoves jec HVAC 1 01-12-2011 10:11 PM
Programmable thermostat and zone issues bawinnicki HVAC 7 01-10-2011 11:23 AM
Line Voltage Programmable Thermostat for Off-peak studhauler Electrical 4 05-11-2010 05:38 PM
Oil Furnace - Swapping out to Programmable Thermostat slappy HVAC 2 12-05-2007 04:57 PM
