Pick Me A Stat - HVAC - DIY Chatroom Home Improvement Forum
Old 10-09-2011, 06:11 PM   #1
Rewards Points: 268
Pick me a stat
I'm convinced, I need a new thermostat. Help me pick one. I have a heat pump. No aux strips. Gas furnace back up. Prefer simple. Daily programming not wanted. I'll take it if I have to but I will probably set the heat to 68* and the AC to 76* and forget it. Sometimes I am home in the daytime, sometimes at night. Its not predictable enough to program in. If you have suggestion, I'd appreciate any you offer. Also where to buy would help too. Thanks.
JackDidley is offline   Reply With Quote
Old 10-09-2011, 06:18 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
The Home Depot sells Honeywell digital stats starting at around $70. I've always liked the look of these screens and they're easy to use. And just because it's programmable doesn't mean you have to program it. Not certain if they come in non programmable although it's a nice feature to have in the event you end up wanting it.
Doc Holliday is offline   Reply With Quote
Old 10-09-2011, 06:28 PM   #3
Rewards Points: 268
That looks just like the one I have that does not work. I think I need an IAQ.
Old 10-09-2011, 06:37 PM   #4
So easy a kid can do it.
Lots of vids on youtube concerning the IAQ.
Old 10-09-2011, 06:48 PM   #5
JJboy's Avatar
LOL
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-09-2011, 06:54 PM   #6
Rewards Points: 268
Looks expen$ive.
Old 10-09-2011, 08:33 PM   #7
Rewards Points: 268
I can get this http://pro1iaq.com/resources/install_manual_t855.pdf For around, $100. Will it do the job ??
Old 10-09-2011, 08:38 PM   #8
JJboy's Avatar
Be sure first if you will be able to configure it.
Old 10-09-2011, 09:27 PM   #9
I think that will work. I probably don't need to say this but I will anyways, make certain all wires go back on the same terminal.
And turn the BREAKER to the furnace off before doing any work.
Old 10-09-2011, 09:46 PM   #10
Rewards Points: 268
Cool. I found it for around $75 on Amazon. Weather is pretty mild so I can still take time and look at my options.
Old 10-10-2011, 04:29 AM   #11
An old Tradesmen
Rewards Points: 7,356
Why not just keep your current non dual fuel stat instead of buying that non dual fuel thermostat.
Get a Honeywell IAQ(YTH9421)with an outdoor sensor.
Old 10-10-2011, 07:52 AM   #12
Rewards Points: 268
From the instructions. Looks like its dual fuel.
This option will turn
the heat pump off 45
seconds after the
auxiliary heat relay
turns on.
For 2 heat
applications, the first
stage will turn off 45
seconds after the
auxiliary stage turns
on.
For 3 heat
and second stage will
turn off 45 seconds
after the auxiliary
stage turns on
Old 10-10-2011, 04:59 PM   #13
An old Tradesmen
Looks like it can work on dual fuel systems. but it uses a poor way to do it. You need a lock out thermostat if you ever turn up the heat during mild weather, or it will switch to the furnace.
Read up on the IAQ.
Old 10-10-2011, 05:45 PM   #14
AKA HVACTECHFW
Rewards Points: 1,208
AGREED iaq!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 10-10-2011, 06:43 PM   #15
Rewards Points: 268
I've not decided yet. Still looking at different options. My visionpro 8000 has an outdoor temp sensor and even though its under the overhang, its still not accurate when the sun is out. Not too crazy about that.
T stat with 2 wires on 240? OffRoadAudio Electrical 6 12-13-2011 06:52 PM
Replacement Thermostat Problem! Confuserated HVAC 8 03-26-2010 08:17 AM
LUX digital stat Trane XE80 intermittant problem rossl56 HVAC 6 12-26-2008 05:53 AM
Which Stat for New Carrier 58 MV Chemist1961 HVAC 10 12-21-2008 06:35 PM
ritetemp programmable stat miked18 HVAC 9 12-17-2007 06:20 PM
