Physical Size Of Central AC Unit - HVAC - DIY Chatroom Home Improvement Forum
Old 06-19-2010, 11:16 PM   #1
Physical size of Central AC unit
I just had a 2.5 ton Trane XL15iAC unit installed (my house is about 1,400 square feet) and it is enormous. If it is so efficient why is it so big? I t seems to me that a unit that big would use more electricity. I keep reading about being careful not to oversize the AC. Does this not apply to the actual size of the unit?
Marjorie is offline   Reply With Quote
Old 06-19-2010, 11:20 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 132
I don't know much about ACs, but maybe it's efficient because the coils themselves are bigger, making the unit itself bigger. I would imagine if the condenser coil covers a larger surface area, it will cool off better, making the compressor work less hard. I might be full of it though, I'm no expert, just speculating.
Old 06-20-2010, 06:43 AM   #3
An old Tradesmen
Rewards Points: 7,816
It is as Red said.
The larger coil surface area. Aids in rejecting heat better. So a smaller horse power fan is used. Which draws less wattage.
A lower head pressure means a lower compression ratio, so the compressor draws less wattage.
Ruud Pack unit "KABOOMS" upon First Light Up of the Day! Wirenut2tite HVAC 18 12-15-2012 10:11 AM
Venting Water Heater near Central Air Unit rchrivera Plumbing 5 03-16-2010 11:03 PM
Central Air Unit is freezing up, all fans working rebuildergirl HVAC 3 06-08-2009 08:42 PM
Central Air unit Temp IntimidatorJD3 HVAC 5 05-11-2009 11:27 AM
Home Central Air Unit has No Freon Recharge Valve nofrey HVAC 1 04-28-2009 07:40 PM
