Pex Pipe - HVAC - DIY Chatroom Home Improvement Forum
Old 01-14-2009, 08:48 PM   #1
Pex pipe
Is it ok to use pex pipe to feed baseboard fin tubing? I would like to add a run in my basement and thought it would make it way easier to use pex.
Thanks.
severancem is offline   Reply With Quote
Old 01-14-2009, 09:14 PM   #2
I have pex running to the baseboard on my first floor, unfortunately my heat isn't working properly(see my post if interested "Hydronic baseboard not working properly"). I have been told the there isn't an issue using pex, infact my base board calls for 3/4'' piping and I have 1/2'' but my plumber (one I trust) has told me that 1/2'' pex has the same flow rate as 3/4''. so in short yes you can use pex
Massed615 is offline   Reply With Quote
Old 01-14-2009, 09:41 PM   #3
I have only used pex for radiant heating, have never used it or seen it used on baseboard. I'm not saying it's not used for baseboard heat though.
SKIP4661 is offline   Reply With Quote
Old 01-14-2009, 10:33 PM   #4
Dr Heat's Avatar
If you can get the proper fittings go for it. Use 5/8 pex for 3/4 copper.
Dr Heat is offline   Reply With Quote
Old 01-15-2009, 06:43 AM   #5
An old Tradesmen
Rewards Points: 6,112
Your plumber is wrong for heating systems.
And thats why yours isn't working right.
Venting ponch37300 Plumbing 41 02-23-2013 11:37 PM
Drain Pipe MrMrsSip Plumbing 2 11-21-2008 06:46 PM
Septic/sewer pipe replacement Mendocino Plumbing 4 11-21-2008 06:40 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 04:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 12:09 PM
