Old 10-31-2011, 06:17 PM   #1
Pex Manifolds
I'm having a hard time finding a pex manifold with 1" pex input x 3/4" outputs.
Everything seems to be 1/2" out only.
Does anyone have knowledge of a manifold w/ 3/4" outs?
This will be used in a hydronic heating application, but no mixing / tempering needed in the manifold - copper would be fine.
Thank you.
OffRoadAudio is offline   Reply With Quote
Old 10-31-2011, 06:59 PM   #2
KemoSabe
loneframer's Avatar
Pex Manifolds
I never saw one with 3/4 outlets. The systems I've seen have such a low flow rate, I cant imagine needing bigger than 1/2" outs. As far as heating output, just close down the spacing on the tubing.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 10-31-2011, 07:16 PM   #3
fabrk8r
fabrk8r's Avatar
Pex Manifolds
You can get a manifold with 3/4" outlets, but it has a 2" sweat inlet and 12 outlets. It only costs $622.95 from PexSupply.
Manifolds with 3/4" outlets are made for very, very large systems.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 10-31-2011, 07:37 PM   #4
Pex Manifolds
any time we needed a pex manifold and was unable to find we made our own from black tees and nipples???????you could make 1" X 3/4 manifold.. you could make it out of any material you want ????
The Following User Says Thank You to ben's plumbing For This Useful Post:
OffRoadAudio (10-31-2011)
Old 10-31-2011, 09:08 PM   #5
Pex Manifolds
This is what I'm leaning toward at this point.
I did see the one for over $600 - puh-lease!
Old 11-01-2011, 07:42 AM   #6
Pex Manifolds
Seen our plumbers make copper manifolds several times. Bet you can have one custom made way cheaper then $600
propex pex manifolds what-do-i-do Plumbing 0 09-28-2011 10:33 AM
Pex Manifold In Attic Lyndon Plumbing 6 05-01-2011 11:55 AM
PEX Manifolds: home-run to each fixture vs grouping runs? drh Plumbing 3 04-02-2008 04:44 PM
Insulation of pex tubing? user007 HVAC 2 12-21-2006 10:44 PM
