Old 11-16-2007, 08:58 PM   #1
pex insulation
Hi,
Just installed new water heating system at home. Plumber who install radiators told me that i must insulate pex pipes in crawling space for heat loss reasons. This crawling space not cold in a winter time (about 50 F), but he told me i Must do it right with the fiberglass insulation (cost $6 for 6') , not with polyethylene foam pipe insulation ( cost $1 for 6' at HD). Guy who install boiler (25 years in heating business) told me polyethylene foam pipe insulation is OK and he use it all the time. I need to insulate 300' of the pex pipes and the price difference is hi! For whom I have to Trust?
Thank you very much for your advices!
ibs325 is offline   Reply With Quote
Old 11-17-2007, 03:38 PM   #2
Journeyman Plumber
Ron The Plumber's Avatar
pex insulation
Use 3/4 wall pipe foam insulation, will be just fine.
Fix it right the first time, so you won't have to fix it a 2nd time.
Ron The Plumber is offline   Reply With Quote
Cape Cod Style House Attic/Crawl Space Insulation Help Danielg Insulation 24 05-21-2012 09:20 AM
basement insulation and vapour barrier coolnes Remodeling 11 02-01-2009 09:56 AM
attic insulation question dderolph Building & Construction 10 11-03-2007 06:21 PM
is there a payback for higher level insulation? walenta Building & Construction 2 10-25-2007 02:07 PM
Installing new insulation in my basement and removing the old moldy insulation. Fixitgeorge Remodeling 3 10-17-2006 09:33 PM
