PEX For HW Baseboard - HVAC - DIY Chatroom Home Improvement Forum
Old 06-29-2009, 07:21 AM   #1
Joe F's Avatar
Rewards Points: 294
PEX for HW baseboard
Any reason I can't use 3/4 PEX in a HW baseboard run? I'm replumbing a basement loop with a few obstacles and PEX would be much easier than using a ton of fittings.
If you don't stand behind our troops, please feel free to stand in front of them.
Joe F is offline   Reply With Quote
Old 06-29-2009, 06:56 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,148
They make high temp PEX for that I believe. I assume it is to supply to the rad and not do the radiating part. Try posting in the DIY plumbing at top of page as well.
Old 06-29-2009, 07:02 PM   #3
Home Air Direct's Avatar
Regionally approved for potable plumbing. Some cities and states allow pex for potable plumbing, and then there are those that only allow pvc and copper. Check with the powers to be in your area for local & state plumbing codes.
Settle down! If you were that important, the city would give you lights and a siren for your car
Home Air Direct is offline   Reply With Quote
Old 06-29-2009, 07:03 PM   #4
I believe the hydronic PEX also has an oxygen barrier to prevent corrosion of the heat exchanger. Check out www.pexsupply.com. They carry both types.
jerryh3 is offline   Reply With Quote
Old 07-11-2009, 11:54 PM   #5
if ya .......
........don't care what it looks like ( sorry , i'm a retired pipefitter).........Jack
psilliman001 is offline   Reply With Quote
Baseboard radiator question timothy918 HVAC 6 11-29-2008 05:00 AM
Tile baseboard with carpet? bpak04 Flooring 2 11-03-2008 01:28 PM
Replaceing Baseboard to curvy wall problem agfrag Carpentry 13 08-29-2008 04:40 PM
convert from gas boiler to electric baseboard marks5894 HVAC 1 10-21-2007 01:22 PM
Need help with finding very wide baseboard Showbiz Carpentry 2 05-28-2007 08:52 AM
