Petcock Needed For Hot Water Radiator - HVAC - DIY Chatroom Home Improvement Forum
Old 03-29-2008, 10:16 AM   #1
Petcock needed for hot water radiator
I am looking for a hot water radiator water supply shut-off petcock(not bleeder valve). It fits a pie shaped shaft in brass L valve. See attached picture. Thanks!
hughrb is offline   Reply With Quote
Old 03-29-2008, 06:30 PM   #2
Custom Cabinet Maker
Hugh, The packing nut will unscrew, wd40 might be needed, then you can take the valve stem to a PLUMBING supply house and they might be able to supply you with a new one.
skymaster is offline   Reply With Quote
Low hot water pressure crebive Plumbing 38 02-26-2013 01:26 AM
Hot Water System -- Cold Radiator formarley HVAC 4 03-04-2008 08:09 AM
I added a radiator to my system and now need to know how to refill enough water memovox2 HVAC 21 01-30-2008 09:27 PM
Water Heater-Imediate Help Needed!!! Willie5566 Plumbing 24 02-25-2007 07:11 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
