Persistant Buzz Thermostat Off - HVAC - DIY Chatroom Home Improvement Forum
Old 02-18-2012, 04:02 PM   #1
Question
Persistant buzz thermostat off
We have a Trane gas furnace about 10 years old. There is a persistant buzz coming from the louvered compartment even when the thermostat is in the off position. There is a master switch located adjacent to the furnace that cuts the power and causes the buzz to stop. I recall the unit was formerly quiet during past inspections and under identical circumstances: thermostat off, power on. I suspect I may need to change something out. Suggested troubleshooting? Am an engineering type, but thought to ask first. Thanks.
entrecreator is offline   Reply With Quote
Old 02-18-2012, 04:05 PM   #2
With a helper at the distant end of an empty garden hose, use your end as a stethoscope to find out which thing is buzzing.
The Following User Says Thank You to Yoyizit For This Useful Post:
entrecreator (02-19-2012)
Old 02-18-2012, 04:07 PM   #3
An old Tradesmen
Rewards Points: 8,170
Could be Transformer hum.
The Following User Says Thank You to beenthere For This Useful Post:
Old 02-18-2012, 04:28 PM   #4
AKA HVACTECHFW
Rewards Points: 1,208
cant find the location of the noise for you over the internet. We can only guess. You will need to locate the noise yourself or call in someone to find it for you. We cant tell you if the noise should be there or not until you find the source. The source is most likely the transformer as Beenthere pointed out.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
The Following User Says Thank You to hvactech126 For This Useful Post:
Old 02-18-2012, 05:34 PM   #5
hvac5646 is offline   Reply With Quote
The Following User Says Thank You to hvac5646 For This Useful Post:
Old 02-18-2012, 05:59 PM   #6
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Transformer or a relay?
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 02-18-2012, 06:36 PM   #7
how
Rewards Points: 1,104
A transformer or relay is the likely cause, as others have pointed out, if it happens when your thermostat is off.
Your longest screwdriver with the handle against the ear works pretty well as a stethoscope if your not sure which component is the source.
PS ..no insult intended but as a cautionary note....
I've found that my clients that are engineers are often the folks that know just enough to mess up themselves or there own furnaces.
how is offline   Reply With Quote
The Following 3 Users Say Thank You to how For This Useful Post:
ben's plumbing (02-18-2012), hvac5646 (02-18-2012), hvactech126 (02-18-2012)
Old 02-18-2012, 06:46 PM   #8
plummen (02-18-2012)
Old 02-18-2012, 07:38 PM   #9
Rewards Points: 582
for sure transformer hum.....
Old 02-18-2012, 07:39 PM   #10
Rewards Points: 582
they know enough to make them dangerous....
Old 02-19-2012, 09:17 PM   #11
Unlike many of my kind, I collect the best information from experienced minds first. I'm also very careful because I cannot afford mistakes and have lots of responsibility. Thank you for this time.
Old 02-20-2012, 08:09 AM   #12
Thermostat issues on old furnace - questions before I replace thermostat. Calab HVAC 11 02-18-2012 08:43 AM
Thermostat for electric baseboard wiring help needed vae_victis HVAC 10 01-05-2012 10:53 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Thermostat issues rathipon HVAC 4 01-29-2011 11:46 AM
Honeywell Prestige HD thermostat wiring 1H/1C + Humidification System TekGamer HVAC 0 07-09-2010 11:58 PM
