Old 12-26-2009, 12:44 PM   #16
Hvac Pro
Perplexing problem, Ruud furnace
Post some pics of the furnace with both doors off so we can recognize it.
Old 12-26-2009, 03:29 PM   #17
An old Tradesmen
Originally Posted by jbarker View Post
I'm not quite sure what you are referring to. If you are referring to the inducer itself, here it is:
http://www.amazon.com/gp/product/B00..._ya_oh_product
No, the heat exchanger style. Rheem early 90% were drum style. And they had problems with them not holding up.
Old 12-27-2009, 09:40 AM   #18
jbarker is offline   Reply With Quote
Old 12-27-2009, 09:45 AM   #19
An old Tradesmen
Do you have A/C with that furnace also?
If so. The coil is probably dirty.
Thats not one of the drum units.
Old 12-27-2009, 09:46 AM   #20
I had some trouble getting the pictures posted, but I think the following links will take you to photobucket account with other pictures of my furnace.
http://i128.photobucket.com/albums/p...2/102_0853.jpg
http://i128.photobucket.com/albums/p...2/102_0851.jpg
Thanks.
-Jay
Old 12-27-2009, 09:47 AM   #21
Hvac Pro
Nothing special about that one and I have seen lots of them. Did you take the condensate trap off and flush it with hot water and Javex/Clorox bleach? May be partly plugged with algae/scuz and slow draining.
Old 12-27-2009, 09:47 AM   #22
No AC with this furnace.
Old 12-27-2009, 09:49 AM   #23
An old Tradesmen
By those pictures you don't have A/C.
The secondary heat exchanger may be dirty. You have to pull the blower to see it.
Old 12-27-2009, 09:50 AM   #24
Hvac Pro
Check my post below your post with links. Dirty condensate traps are a common problem.
Old 12-27-2009, 09:53 AM   #25
The black pipe to the left of the blower has been perfectly bone dry every time I have taken it apart, (and that has been alot over the past 4 weeks). I don't think that a clogged drain is the problem.
To re-hash things, I have a clear inlet and exhaust pipe, new inducer, have confirmed the port on the inducer is not obstructed, and the inducer only prodeces 3/4" WC of vacuum, when it needs to produce a minimum of 1.11" WC to close the pressure switch. Thanks again for your continued interest.
-Jay
Old 12-27-2009, 09:58 AM   #26
When I pull the inducer, I have access to a hole in the heat exchanger about 2" in diameter. When I look in there, it looks clean, but I'm not sure if that really means anything.
Does a dirty secondary heat exchanger LOOK dirty, or is the problem deep inside?
If it is clogged up, is there a way to clean it, or does it need to be replaced?
Old 12-27-2009, 11:06 AM   #27
Hvac Pro
On most units you can remove the collector box where the inducer fan attaches and inspect the tubes which spill into the collector box and drain for black scuz (carbon) from the propane. There may be turbulators in the coil tubes and they may be dirty. Only way to know is to remove the collector box and visually inspect the secondary coil tubes. Buy a new gasket for the box B4 you take it apart and put some red rtv silicone on the new gasket when you install it or you may get water and vacuum leaks later.
Old 12-27-2009, 12:16 PM   #28
An old Tradesmen
First. what are you using to check the pressure?
A digital manometer, or a water tube?
Old 12-27-2009, 12:37 PM   #29
Jay, have you called the supply house where you bought the inducer or a tech support line? I have seen other furnaces spec a different pressure switch when the inducer was replaced. Not saying that's the problem but it is worth looking into.
Old 12-27-2009, 08:13 PM   #30
Did you buy the inducer from Amazon? Might try an OEM part if so.
Mike in Arkansas is offline   Reply With Quote
Ducane gas furnace problem rugger HVAC 4 04-10-2009 08:01 AM
Ruud furnace problem Paul T. HVAC 8 12-07-2008 07:25 AM
Carrier Furnace Problem Boats1183 HVAC 1 11-11-2008 07:41 PM
another question for a miller furnace problem jb9270 HVAC 1 02-05-2007 03:04 PM
