Permits - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2011, 12:28 AM   #1
42nat1's Avatar
Permits
I have a bit of a problem.
I am finishing a 1/2 story attic built in the 50's. I have pulled my construction permit and anticipate pulling my electrical permit.
I am now considering running my central air to the space (heater is adequate size), however HVAC Folks I have had come and look at it for bids have told me that the system in place throughout the house is clearly not to code due to undersized pipes and an octopus coming off the top.
My question: 1) will the prior work present a problem for me if I want to pull a permit? , and 2) if I have someone do the work anyway and bring it close to code is there any type of grandfather that would normally apply.
42nat1 is offline   Reply With Quote
Old 12-07-2011, 06:26 AM   #2
The only people who can answer that are the ones who issue the permits.....
harleyrider is offline   Reply With Quote
Old 12-07-2011, 06:33 AM   #3
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
The towns and codes I work in and around say if you touch it, you must bring it up to code.
If you don't...you can leave it in there.
tcleve4911 is offline   Reply With Quote
Tags
hvac , permits
Permits on partially completed addition just Building & Construction 4 04-19-2012 11:27 PM
Estimate for plans + permits + sub-foundation stuff + foundation? shinyhalo Building & Construction 5 10-07-2011 08:29 PM
Help ... permits joyjoy Remodeling 2 11-26-2010 06:30 AM
permits / inspections evill Building & Construction 18 11-29-2009 08:27 PM
